Is this normal on a cossie?
Old Aug 11, 2008 | 08:30 PM
m4ttyrs's Avatar
m4ttyrs
Default Is this normal on a cossie?
I have an escort cosworth which until recently had a standard oil breather kit on it, after i changed this for a bailey oil breather i removed the filter for a good clean to remove all the engine oil deposits job done filter nice and clean and oiled. Took my filter off the other day about 2 months after the breather was fit and left it stood up in my garage, came to it this morning and there was a big pool of oil around the filter almost certainly engine oil. Now is this normal? I thought once i had removed the standard breather pipe from the filter the filter would stay nice and clean. Any help would be appreciated thanks. Matt.
Old Aug 11, 2008 | 08:34 PM
m_nettleship's Avatar
m_nettleship
Well on my 2wd, after 4 months, all the pipes on the breather was caked up, gunge and the lot, no not a blown head gasket,
so u running pipe bk to the filter box then.
Old Aug 11, 2008 | 08:36 PM
rapidcossie's Avatar
rapidcossie
DO NOT return the breather to the air box!
Old Aug 11, 2008 | 08:45 PM
m_nettleship
Thats wat i thought., run it to the ground. try to pipe it bk a little, under the car.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
