escos oil leaks.. help needed
Old Aug 10, 2008 | 07:40 PM
bluebones's Avatar
bluebones
Default escos oil leaks.. help needed
Hi, had oil leak on my 1994 escos. It was coming from cam seals and rocker cover. So I have now replaced the seals and rocker cover gasket, problem is the leaks are even worse. I bought the parts from Woodford's and they gave me an extra 2 seals which are the two O rings. Does anyone know where these go as I have looked through the manual and can't find a place for them? These O rings are the same size as the circumference of the cam bit I am baffled as to where (in between the bearing and spacer etc) they go? Or are they not needed?
Any way back to the oil leak, I don't know where I have gone wrong, I have used all genuine parts and have the manual and also I have recently changed the water pump and cambelt and have noticed the cambelt looks like it has been rubbing against the water pump. Again these were all genuine parts used. Appreciate any help from anyone that might have experienced the same problems. Thanks, George.
Old Aug 10, 2008 | 07:48 PM
turbocat's Avatar
turbocat
I would 100% say the reason its leaking is because you have not fitted the half moons. They go at the front of the engine over the cams they have a small gap for them I think the rocker cover has to. You will have to take the rocker cover off again
Old Aug 10, 2008 | 07:52 PM
mechanic28's Avatar
mechanic28
those O rings might be causing the leak,i presume they a green O rings?not sure if you have to take the cam out to fit them?i do not think so tho?
Remove cambelt then remove cam pulleys undo the 10mm bolt which was behind then pulley remove cam cover undo the 8mm nuts on the front cam caps remove caps,slide cam races out and you will see the O rings on the race housing!
Did you use sealant on the half moons?what cam cover gasket did you use?
Old Aug 10, 2008 | 07:53 PM
mechanic28's Avatar
mechanic28
as for the cambelt i think you have gone the wrong way with the tensioner when applying tension to the belt you need to go clock wise!
Old Aug 10, 2008 | 07:56 PM
ECOS95's Avatar
ECOS95
Make sure the half moons are the same colour as the ones you removed. I ended up with different coloured ones & they didn't fit correctly.
Old Aug 10, 2008 | 08:19 PM
bluebones's Avatar
bluebones
they are all guniune parts from woodfords, half moons are fitted and not leaking from that.
looks as the rocker cover is leaking,which is guniune ford one, so is they any tricks or tips needed to stop this,and cam seals leaking as it has made a bit of a mess.
i did take the cams out to fit them as i was told they had to be fitted before the bearing..., they are black in colour.
Old Aug 10, 2008 | 08:32 PM
mechanic28's Avatar
mechanic28
get a cometic rocker cover gasket fella much better!make sure you get the gasket tucked nicely in the slots around the half moons,i used vauxhall black sealant to help seal as well!
Old Aug 10, 2008 | 08:33 PM
mechanic28's Avatar
mechanic28
the o rings are green form ford i sem to remember?unless you are talking about the cam seals and not the cam race housing O ring seals?
Old Aug 10, 2008 | 08:40 PM
bluebones's Avatar
bluebones
the old cam seals i removed where orange, new ones are black. the cam "O" rings are black as well, but where do these go? as i have fitted them to the inside of the cam against the bearing,(had to take the cam out) but now ive been told that 4x4 do not ust the cam "O" ring. these are the small flexible ones.
Old Aug 10, 2008 | 08:44 PM
mechanic28's Avatar
mechanic28
on mine they fitted to the outside of the cam race housing not sure if its different on a escos i presume not as you would of seen them when you removed the cam??
Old Aug 10, 2008 | 08:47 PM
bluebones's Avatar
bluebones
well this is the point, they never had them fitted,this is why im confused.
Old Aug 10, 2008 | 08:57 PM
mechanic28's Avatar
mechanic28
hmm there would be a groove cut out to accept the O rings on the out part of the cam race housing
Old Aug 10, 2008 | 09:22 PM
bluebones's Avatar
bluebones
thanks for your help bud, going to take apart again tomorrow and see what happens.
Old Aug 12, 2008 | 03:33 PM
cossytel's Avatar
cossytel
The o rings go between the bearing and spacer, make sure the spacer is the correct way round the inside is chamfered on the side next to the bearing. if you have removed the front bearing caps then you need to apply sealer between the head and cap to stop oil seeping between. also apply sealer to joint between half moons and gasket (4 places) I also put sealer on inside of spacer finally dont over tighten cam cover bolts, you can split gasket especially cheap ones, hope this helps.
Old Aug 13, 2008 | 03:41 PM
bluebones's Avatar
bluebones
thanks bud!! great help as i forgot which way the spacers went..just brought some new seals from fords and going to give it another go before i hand it over to a garage.
james kiely
Aug 28, 2015 08:58 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
c20tbo
Aug 17, 2015 10:19 PM
col93saphcos
Aug 7, 2015 03:21 PM
