mk5 xr3i alternator trouble
Sorry if this sounds a wee bit stupid but its my first ford... I need help fitting an alternator belt. The cars a mk5 xr3i 1.8 130. I need the route and where the tensioner is. Pics would help loads.
Cheers.
Cheers.
PAS - power steering pump
WP - water pump
G - guide
GEN - alternator
T - tensioner
CS - crankshaft
AC - air con pump
Tensioner should be a 15mm socket/spanner and is spring loaded
turn it clockwise if i remember untill you can slip the belt off then slowly let tensoin off. To refit just turn clockwise again untill you can slip the belt back on.
Easy peasy
07-10-2015 12:56 PM
