mounting map Sensor
Old Jul 26, 2008 | 10:08 AM
Pat's Avatar
Pat
Default mounting map Sensor
Someone told me that the map sensor has to be mounted a certain way.. ie the plug needs to be at the top!!! Is this true?? At the mo its mounted where the plug is at the bottom..
Old Jul 26, 2008 | 10:24 AM
NATH-RSZT's Avatar
NATH-RSZT
what sort of map sensor. if your talking about an ofab one then the vacume pipe needs to be facing down also its ment to be eathed.
Old Jul 26, 2008 | 10:51 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
A 2/3 bar MAP sensor for a Cosworth needs to be mounted upside down
This is so the internal pressure sensing part has the correct 'zero setting' to start with before any pressure/vacumm is applied
Old Jul 26, 2008 | 12:32 PM
Pat's Avatar
Pat
Default map
Sorry forgot to put its on my ERST 2.1 zvh... Has a 3 bar on it!!
Old Jul 26, 2008 | 09:57 PM
SafeChav's Avatar
SafeChav
Doesn't need to be earthed by the screws, its all in the wiring
Old Jul 26, 2008 | 10:01 PM
trevCOSS's Avatar
trevCOSS
yes its in the wiring but one of the screw holes has an earth tab suggesting that that screw should go to earth as it does in the oe application
Old Jul 26, 2008 | 10:04 PM
SafeChav's Avatar
SafeChav
Indeed, works perfectly fine without though!
The installation on a FRST is very crude in this respect aswell.
Old Jul 26, 2008 | 10:06 PM
Mark Shead's Avatar
Mark Shead
The nipple needs to face downward as this is to stop moisture/oil getting in to it and damaging it.
Mark
DixieTheKid
11
Jun 6, 2020 11:20 AM
jay030787
Sep 25, 2015 01:38 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
tib2220
Sep 14, 2015 12:33 PM
