escos banana pod gauges ilummination problem
Old Jul 16, 2008 | 05:32 PM
davidfox280585's Avatar
davidfox280585
Default escos banana pod gauges ilummination problem
bought a set of these for my escort van as already had pod ive looked on the back and there is place for two plugs a two pin and one five pin maybe six but anyway the two pin i beleive is illumination but doesnt illuminate when given a pos and neg wondered if this is a fault as bought them from fleabay any help will be great
Old Jul 16, 2008 | 07:47 PM
kjc300's Avatar
kjc300
it needs an inverter mate, normally it gets the feed from the main dash clocks as the inverter is in there.
Old Jul 16, 2008 | 08:52 PM
davidfox280585
thanks kev............... any ideas how i can get around this cheers
Old Jul 16, 2008 | 09:12 PM
kjc300's Avatar
kjc300
yes mate - two ticks
here's the wiring diagram
Old Jul 16, 2008 | 09:13 PM
kjc300's Avatar
kjc300
pin 1 and 2 you need on the above diagram.
I'm just finding the website I used for the inverter....
Old Jul 16, 2008 | 09:26 PM
kjc300's Avatar
kjc300
http://www.litewave.co.uk/glow_wire.asp
scroll down to
12v Glow Wire Inverter, no Glow Wire: £13
Thats what you need mate, connect the feed to the box (cig lighter end - make sure you get the pos and neg right) to the illumination feed from one of the dash switches i.e. fog or heated rear screen (normally the top single wire on the switch) and the other to an earth.
The output end to the pins 1 & 2 on the pod (doesn't matter which way round these go as it's AC from there)
job done!!
ps. I'm assuming you have a mk5 van!!
Old Jul 17, 2008 | 06:08 PM
davidfox280585
just going to order one now thanks mate you have been a great help as i thought they were faulty will let you know how ive got on and yes its a mk5 td van
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
Mickeystewart
Sep 9, 2015 04:04 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
