S2 Main beam Failure - SORTED
Old Nov 2, 2004 | 12:37 PM
Spax's Avatar
Spax
Default S2 Main beam Failure - SORTED
ok,
My Alternator light has been on very lightly when I first start up in the mornings for like 3 secs then fades away, it's been starting fine etc,then last night went to turn my main beam on and they didn't turn on, the sidelights are fine so is Full beam,but when I turn from the sidelights to main beam they dim,and when i turn them back to sidelights they glow a little brighter, having to drive with my Full beam on last night,could both bulbs have blown at once for the main beam? loose earth? just seems strange,or maybe a relay popped? sometimes there was a 2 or 3 second delay when I turned them on? or maybe the Lever is buggered? any help please?
Thanks
Spax
*Burn't out relay,just swapped it for my Full beam one until tmw
Old Nov 2, 2004 | 02:36 PM
Spax's Avatar
Spax
Just tried it and it works again,could be a loose wire somewhere...any ideas where? switch end or light end? thanks
Spax
Old Nov 2, 2004 | 07:47 PM
phil robson's Avatar
phil robson
i had a similar problem on mine a couple of years ago, check the headlamp relay (its one of the little ones in the fuse box)
Old Nov 2, 2004 | 08:24 PM
Spax's Avatar
Spax
ok cool, u think it may need replacing?
Old Nov 2, 2004 | 08:39 PM
Alvyn's Avatar
Alvyn
it's the switch(stalk) that turns the lights on the blink common fault on s/2 m8
Old Nov 2, 2004 | 08:45 PM
Spax's Avatar
Spax
ahh ok cool, there easy to change yer? also the other side wiper one has started playing up, it will stop the wipers mid sweep if i move the stick instead of putting em back to the non moving state
Old Nov 2, 2004 | 09:15 PM
Alvyn's Avatar
Alvyn
take it their both due a change then piece of piss to change
Old Nov 2, 2004 | 09:18 PM
Spax's Avatar
Spax
ahh ok nice,i'll grab some tmw, any ideas how much they are?
Old Nov 5, 2004 | 07:41 PM
Spax's Avatar
Spax
Got a new wiper stalk today for Ł61.00!
still hasn;t cured the problem which is very annoying, no main beam at all just sidelights and even dimmer main beam when selected, altho full beam is fine?
Anyone got any other ideas? relay faulty? dodgy earth somewhere?
Thanks
Spax
Old Nov 5, 2004 | 07:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Faulty relay in your fuse box m8,mine did that last year i prised the terminals out a bit and it's been fine since.
Old Nov 5, 2004 | 08:06 PM
phil robson
when you say main beam do you mean dipped headlamps,if so the relay or relay holder should be marked with a letter j,try swapping it with a one the same colour if there is one but if not go down to your local scrapyard for one,should only cost a couple of quid(gotta be worth a try)
Old Nov 5, 2004 | 10:31 PM
Spax's Avatar
Spax
Yer sorry Dipped headlights,i.e normal driving beam.....It's doing my head in!
Old Nov 5, 2004 | 10:32 PM
Spax's Avatar
Spax
Ahh ok, i'll give it a try,don't spose u know whixh it is do u?
Old Nov 6, 2004 | 06:51 AM
KSA-Cossie's Avatar
KSA-Cossie
I think it was a brown one,put your lights on then wiggle the relays and it'll probably work.
Old Nov 6, 2004 | 10:49 AM
Spax's Avatar
Spax
wicked thx mate i'll give it a try gonna take the new bit back monday hopefully they understand
Old Nov 7, 2004 | 06:01 PM
Spax's Avatar
Spax
No change
Dunno whats wrong? only other thing I can guess is a popped relay, I've checked everything else
Gonna take back the light stork tmw and change it for some relays,theres a relay on the sotrk itself on the steering column could this be buggered or the one in the fusebox? thanks
Spax
Old Nov 8, 2004 | 06:59 PM
Spax's Avatar
Spax
BTTT
Old Nov 9, 2004 | 08:07 PM
phil robson
was it the relay
Old Nov 9, 2004 | 08:19 PM
Spax's Avatar
Spax
yer it was, altho i's playing up a little still ?!
20/20 vision
Sep 28, 2015 03:03 PM
DavidK
Sep 27, 2015 02:55 PM
