turbo difference
Old Jul 7, 2008 | 07:05 PM
mk3cab's Avatar
mk3cab
Default turbo difference
what difference is there between the t3 and the t34 turbo unit also what boost pressure can they hold
thanks matt c
Old Jul 7, 2008 | 07:09 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
T34 is a hybrid turbocharger developed by Garrett/Ford for the early Escort Cosworths. It has a T3 turbine housing/wheel/shaft, mated up to a T04b compressor. The amount of boost depends on the engine.
T3's aren't really much good over 250bhp, short-lived at 300bhp on the biggest T3.
Old Jul 7, 2008 | 07:13 PM
mk3cab's Avatar
mk3cab
will the t34 hold 28psi?
Old Jul 7, 2008 | 07:14 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
As I said, depends on the engine.
Old Jul 7, 2008 | 07:21 PM
mk3cab's Avatar
mk3cab
ok im looking at going full zetec turbo with ms management next year. steel rods forged pistons. 3 bar map, ect. hopping 300+bhp. im running 2.1zvh now with a stage 3 t3 turbo as you said the t3 aint much good after 300. also would i have to change the actuator from a -31 to a -34?
matt c
Old Jul 7, 2008 | 07:23 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No, a -31 is fine. T34 is a great turbo for 300bhp on a 2L zetec turbo.
Old Jul 7, 2008 | 07:37 PM
NEWTON's Avatar
NEWTON
what sort of boost would you have to run for 300bhp,i know it will depend on engine spec,say big valved ported and polished head,steel rods forged pistons etc etc
Old Jul 7, 2008 | 09:10 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
NEWTON- on a standard (head) 16v engine about 1.4 bar, probably about .2 more for an 8v.
Old Jul 8, 2008 | 12:51 AM
NEWTON's Avatar
NEWTON
thanks mate
Old Jul 9, 2008 | 12:21 PM
Maki's Avatar
Maki
Why more boost on 8v head? explain please
Old Jul 9, 2008 | 12:43 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The CVH is a dirty old pig and doesn't burn as efficiently as a Zetec. You tend to need a 'bit more of everything', turbo size, injectors, etc.
Old Jul 9, 2008 | 12:53 PM
Maki's Avatar
Maki
aaa you see it through that angle. In that case maybe you know how many cfm do both heads flow?
Old Jul 9, 2008 | 01:21 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Which heads? You'd have to choose two particular heads (eg, mfi rs turbo and a 2l zetec silvertop etc)..
The CNC heads website has a bunch of flow figures if you're interested.. I don't own a flowbench myself!
Old Jul 9, 2008 | 01:34 PM
Maki's Avatar
Maki
Just thought that you will know... I only heard that CVH head even ported and with big valves will flow less than Zetec head.
what is the link for the CNC heads? Edit found it thanks
Old Jul 9, 2008 | 01:42 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
www.cncheads.co.uk I think
Standard zetec head should flow around 450-500CFM.. std CVH i'd predict around 350.
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Hellraiser
Aug 8, 2015 04:19 PM
