Wires going to coilpack
Old Jul 5, 2008 | 05:14 PM
S2Steve's Avatar
S2Steve
Default Wires going to coilpack
Right on my efi rs turbo, one of the positive wires sheared itself off right near the connector. I have soldered it back on but it now can slip in and out of missfiring because of the bad connection. Can you run a new wire through into the onnector or will I have to get a new connector? If so does anyone know the name of it or part no. ? Cheers, Steve.
Old Jul 5, 2008 | 10:46 PM
sortedsaff's Avatar
sortedsaff
there is loads of the new connectors on ebay matey.
ill try find a link for you
Old Jul 5, 2008 | 10:54 PM
sortedsaff's Avatar
sortedsaff
http://cgi.ebay.co.uk/Ford-Cosworth-...d=p3286.c0.m14
that should do the trick
Old Jul 6, 2008 | 06:57 AM
polevolt.co.uk
They sell all the connectors NEW that you need, I have shed loads of them too if you have trouble, the one shown in the ebay link is of course NOT a coilpack connector, and is expensive too, but if needed I have lots of these too.
Old Jul 6, 2008 | 08:31 AM
S2Steve's Avatar
S2Steve
Do ford sell them? Can't find the one I need on ebay, only one i could find at £35 with a oil pressure wire too! I'll try polevolt if ford don't stock them.
Old Jul 6, 2008 | 05:09 PM
If it's a std coilpack connector ford will not afaik sell them.
Old Jul 6, 2008 | 06:38 PM
SafeChav's Avatar
SafeChav
Why not just go to the scrapper and cut a plug off? Anything with an EFI CVH or a Zetec will be fine.
i did the same thing for Chunt69 when i converted his to EFI because the plug on his loom was shagged.
You can also then cut off as much wiring as you need aswell
Old Jul 7, 2008 | 05:46 AM
Just be aware there are more than 1 type/fitting coilpack plug.
Old Jul 7, 2008 | 10:19 AM
S2Steve's Avatar
S2Steve
I sold the car anyway, its someone elses issue now
Old Jul 9, 2008 | 02:02 PM
SafeChav's Avatar
SafeChav
Old Jul 10, 2008 | 05:13 AM
That was drastic, selling a car because of a plug!!
Old Jul 14, 2008 | 02:26 PM
SafeChav's Avatar
SafeChav
I doubt very much he sold the car just because of a coil pack plug!
Old Jul 22, 2008 | 01:31 AM
S2Steve's Avatar
S2Steve
haha of course not, it was on sale before that business happened with the dodgy wire!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
