3 door oil leak
Old Jul 4, 2008 | 09:38 PM
magentasafchris's Avatar
magentasafchris
Default 3 door oil leak
Right people just got my three door running today after having it sat in my garage for nearly four month's and it's pissing oil out from around the number 1 piston exhaust manifold. It looks like its running from the manifold itself where it bolt's to the head it's a bit of a strange one. If you rev it it seems to splatter it out but when it tick's over it just dribbles down the block at a steady pace. I checked the oil feed and drain from the turbo and they are both intact. Any clues or ideas would be great, trying to get it finished for ford fair but if i can't sort this oil leak then that's out the window.
Old Jul 5, 2008 | 06:59 PM
320 bhp's Avatar
320 bhp
did you get my pm?? its comming from were i removed the breather system there was a fitting under the manifold oil return to block i think
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
