What is this on a EFI setup ?
Old Jun 29, 2008 | 08:42 PM
S2_RST_DK's Avatar
S2_RST_DK
Default What is this on a EFI setup ?
Hi
I have got the EFI setup on my rs turbo, but there are 2 things that i need help for. I simply do not know what they are
One is a yellow connection beneath the fuelrail. What is it ??
The connection above the hole for the vacum hose, what is that ??
Thanks
Henrik
Old Jun 29, 2008 | 08:55 PM
NATH-RSZT's Avatar
NATH-RSZT
The yellow one is the engine temperature switch and that vacume can be used for dump valve boost gauge etc
Old Jun 29, 2008 | 09:21 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Isn't that port used for the brake servo?
Old Jun 29, 2008 | 11:10 PM
zetecturbo's Avatar
zetecturbo
that take off is where the vacuam pipe for the map sensor goes and the hole below it is for the brake servo pipe ,by the looks of ur picuve still got the pipe for the rs turbo mfi manifold ,ul need 1 from any efi mk4 xr3i
Old Jul 1, 2008 | 06:59 AM
S2_RST_DK's Avatar
S2_RST_DK
Thanks
But .... the top take off for the map sensor, since i am using the Gotech ECU, do i still need to plug it to a map sensor ??
Henrik
Old Jul 1, 2008 | 08:05 AM
picky775's Avatar
picky775
Originally Posted by S2_RST_DK
Thanks
Henrik
You have to run a hose to your gotech ecu from that pipe as the map is in your ecu.There should be a small piece of tubing coming out of the ecu,that is what it joins to.
timsrs
Nov 13, 2018 11:48 AM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
