WASTEGATE/ACTUATOR boost pipe
Old 31-10-2004, 11:54 AM
scooby8272
scooby8272's Avatar
Default WASTEGATE/ACTUATOR boost pipe
where is the best place to take a referance point form for the above.
Should your wastegate / actuator boost pipe come from the compressor housing or from the inlet plenum ?
Pro / cons ?
Old 31-10-2004, 12:07 PM
sammy
sammy's Avatar
generally there all from the compressor housing to the wastegate actuator,(sometimes having a boost controller between the two) well all the ones ive seen anyway.
Old 31-10-2004, 12:31 PM
Azrael
Azrael's Avatar
Do all the turbos including modern ones have boost pipe take-of in compressor housing? I ask because I didn't see many Garett turbos.
Old 31-10-2004, 04:14 PM
scooby8272
scooby8272's Avatar
I am using a GT28 and it has no take off valve on the compressor.
Hence the question ?
timsrs
13-11-2018 11:48 AM
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
mpilk
27-09-2015 09:21 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: WASTEGATE/ACTUATOR boost pipe
