1993 escos power issue.
Old Jun 25, 2008 | 11:34 AM
escosworth1's Avatar
escosworth1
Default 1993 escos power issue.
Hi guys ive not been a member on here for that long and not to long ago bought a big t escos off here.
Since owning and driving the car ive noticed that when you give it a boot full especially in the earlier gears 1,2,3 it revs up to around 5k 6k then all of a sudden it jolts and no power as if its just cut off. Is this normal as i expect not but im unsure as im still learning about the car. The car is standard.
Thanks for your time. Rob
Old Jun 25, 2008 | 08:24 PM
escosworth1
anyone
Old Jun 25, 2008 | 08:33 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
could be overboosting, but i seem to recal that the boost comes off really quick on the standard ones?
Mine havent been standard for over 8 years now so cant really recal tho
What boost are it running? overboost and what can it hold?
Old Jun 25, 2008 | 08:34 PM
Trev_rev's Avatar
Trev_rev
When You Find Out Let Me Know As Mine As Been To A Few Garages And Still Same...but 4k And Cuts,had All New Sensors And Ecu Loom Has Been Checked And The Conector Blocks Removed And Hard Wired????????
Reckon I Scrap The Bloody Thing................
Old Jun 25, 2008 | 08:39 PM
escosworth1
Its totally standard as fare as im aware.
im not sure what boost its running. And i thought it was overboosting as the gauge does go into the red why would it overboost and what would be causing it.
Old Jun 25, 2008 | 08:56 PM
LHD220Turbo's Avatar
LHD220Turbo
try posting in general discussion mate, nobody is hardly ever in Tech help
Old Jun 25, 2008 | 09:07 PM
escosworth1
am i ok to put it in there
Old Jun 25, 2008 | 11:28 PM
velocity's Avatar
velocity
had this problem before with an escort cosworth, car would die at 4k revs or there abouts, and would be fine up to that, it was the lambda sensor that was toast, and without it the ecu wont let the engine go above 4k revs without limiting, changed the sensor and it drove pefect. so i unless its been changed or the wireing to it checked out. i would try it.
Old Jun 26, 2008 | 04:14 AM
stevecossy's Avatar
stevecossy
Try posting in the escort cossy section mate lots of helpful guys on there, and as said gen diss also.
Good luck
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
