help please stage 2 t3
Old Jun 23, 2008 | 06:12 PM
lee s1's Avatar
lee s1
Default help please stage 2 t3
hi i have just had a stage 2 t3 turbo built and it could do with being water cooled and as it is going on my series 1 it is not water cooled from the factory,tapping in to the water feed should be quite easy but i need to find the two connectors for the turbo unit has anyone elce done this before and knows where i can get the bits from or an easy way to do it.any help would be apreciated thanks lee
Old Jun 24, 2008 | 11:12 AM
All you need is a couple of banjo bolts, some copper "O" rings to go on each side of the pipe ends that you will need to buy as well, if it has a water channel in the core/bearing housing then the later water cooled ones bits would most likely be the eaisest way.
Someone like PARKERS would sell all the bits needed.
Old Jun 25, 2008 | 09:22 PM
lee s1's Avatar
lee s1
Thanks for that where would you take the water feed from somewhere like heater matrix or the standard oil cooler water feed pipes ? thanks lee
Old Jun 25, 2008 | 09:41 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Your turbo will be fine without water cooling you know, I ran my Stg 3 T3 for god knows how long with no issues.
Std RST water pipes should already have the feed/return for the cooling anyway if you really want to do it
Old Jun 25, 2008 | 10:52 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
isnt the rs turbo series 2 only watercooled from the factory so it illiminates the need to let the turbo cool down after a run than say using one which doesnt have water cooler ie the series 1 where its best to let it cool before switching it off ????.
dave
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
