Rubber in propshaft knuckle
Old Jun 23, 2008 | 10:57 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default Rubber in propshaft knuckle
Just wondering, the propshaft on my 4x4 that goes from gearbox/transfer case to the front diff has play in the knuckle again !
I replaced it not that long ago with a s/h item which I guess what on its way out.
Can the rubber bits in the knuckle be replaced ? Are they available separately ?
Old Jun 23, 2008 | 12:51 PM
iansoutham's Avatar
iansoutham
OCD Victim
You can buy a new uj joint for these. Most motor factors list it but will supply the rear prop one instead, but there is a place near me that can supply brand new QH joints (4 way spider part) for silly low money.
I had to get one for my 4be Saff TwinCam last year.
If you want, I will dig out their details and the part number which I get the chance?
Cheaper than replacing a perfectly good front prop otherwise.
Old Jun 23, 2008 | 01:01 PM
frog's Avatar
frog
Just found out Ford do a replacement spider for £64.95 each end
Would be great if you could, could do without spending £130 on bits of rubber !!!
Old Jun 26, 2008 | 09:10 AM
frog's Avatar
frog
I've managed to get a replacement spider for the UJ from woodford for £64.95
Then found out that what you need from QH is in this post !!!
https://passionford.com/forum/general-car-related-discussion/139921-propshaft-uj-questions.html
Front prop UJ
Quinten Hazel Part number QH QL16103
Cost me £26.88 incl VAT
Wish I'd searched a little more.
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
Vacuman
Sep 22, 2015 12:09 PM
