ecu
Old Jun 18, 2008 | 07:54 AM
raycov's Avatar
raycov
Default ecu
can you run a wideband controller on a l8 closed loop ecu or has it got to be a narrowband.
i have conflicking reports any help would be much appreciated.
cheers
Old Jun 18, 2008 | 08:16 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Narrow band only... although some wide band kits also give a narrow band simulated output which you can use.
Old Jun 18, 2008 | 08:38 AM
foreigneRS's Avatar
foreigneRS
Testing the future
as above. a narrow band lambda sensor gives an output from 0 - 1 V that changes very sharply around lambda = 1
most wideband controllers can give an output that simulates that, so can be used for both tuning and AFR monitoring, and closed loop fuelling
Old Jun 18, 2008 | 10:30 PM
raycov's Avatar
raycov
Default ecu
thanks for the information so who sells the best widebands.
cheers
Old Jun 19, 2008 | 06:27 AM
There are loads to choose from, with very different prices, so make a list of what YOU want from an ecu and compare specs/prices.
Look also for back up/advice available should there be questions/problems, future upgrades.
I have just got for the one which I like the best for me, emeraldm3d.com I have the K3 from these people, and live about 500 metres away !
Old Jun 19, 2008 | 08:08 AM
foreigneRS's Avatar
foreigneRS
Testing the future
he didn't ask about ecu's tabetha, he's asking about wideband controllers
i think i saw your mate dave walker in watton on saturday driving a silver estate, maybe a 407?
raycov, do a search, there are loads of threads on here about wideband controllers and many people have their favourites
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
