please help... cossie oil leak problem???
Old Jun 15, 2008 | 07:32 PM
rossco22's Avatar
rossco22
Default please help... cossie oil leak problem???
just picked up my new car, westfield sew cossie powered 2wd
slight problem!
whenever come to a stop after trip out, have a look at engine and there is a puddle of oil on top of rocker cover at one end... cam cover end
also seems to be oil coming out from top of dipstick...
have replaced oil filler cap 3 times with no joy...
seems as if it comes from the cap...
why would this be?? breather system problem maybe??
bottom end sounds fine, no knocks...
rebuilt 20k ago... starts from cold fine... just seems to have this problem??
any ideas/remedies would be appreciated!!
Old Jun 15, 2008 | 08:28 PM
rapidcossie's Avatar
rapidcossie
it can come out of the bolts that hold the cam cover on.
take them out and put a small amount of silicon sealer on them when going back in.
Old Jun 15, 2008 | 08:40 PM
rossco22's Avatar
rossco22
thanks for that... will have a look tomorrow...
so, am i right in thinking, reason for the oil leaking, is due to excess pressure???
if so, i did notice hole at opposite end of cover next where oil breather system is plumbed into... which would surely let any unwanted pressure out??
also, system has an oil catch tank??? does this make a difference or help with solving problem??
but sure it is coming from oil filler cap?
Old Jun 15, 2008 | 09:32 PM
mechanic28's Avatar
mechanic28
Is there a pipe conected to the breather out let?could also be leaking from around where the breather port goes into the camcover
Old Jun 15, 2008 | 10:11 PM
rossco22's Avatar
rossco22
pic of engine minus oil!!!!
the breather system is as far as i know connected up correctly...
is there a common problem with these blocking??
Old Jun 16, 2008 | 05:20 AM
You could put the additional breather on the rocker cover by drilling it out at the rear after taking it off, this would help, as would pre loading the cap, cut a ring out of a cereal box and place between the cap and the seal that goes on the cap, you may need two but it will work and is free!!.
Old Jun 16, 2008 | 07:42 AM
rossco22's Avatar
rossco22
Ok thanks ill try the cereal box idea today and see how i get on, will post back the results,
The thing i dont understand is why is there so much pressure around the oil cap area? there is approx an 8mm hole drilled into the the rocker cover opposite the breather system next to were the battery is situated and its not blanked off, why if theres alot of pressure doesnt it start coming out of there??
I will get some more detailed pictures up later on to see if this sheads any more light on the situation...
Old Jun 16, 2008 | 08:04 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Another Tabetha classic
Old Jun 16, 2008 | 11:23 AM
rossco22's Avatar
rossco22
Right ive fitted the cardboard gasket around the oil cap, that seems to have 90% sorted the leak from there, but i still have oil coming from the dipstick & now it seems as though theres oil coming out of the breathers??
here are some pics of the set up if it throws any light on it?
Old Jun 16, 2008 | 01:53 PM
The hole you mention is at each end of the rocker cover, and is in the PLUG area not the oily bits, this is so that no condensation forms around the plugs/connectors to cause misfires.
You are using both or just the one block breather ?
Old Jun 16, 2008 | 08:27 PM
rossco22's Avatar
rossco22
Ok that solves the mistery with the hole then, not sure how you mean both or one block breather? This evening ive had the kidney box of an cleaned that out , blown through all the breather hoses to check for blockages and drained the oil catch tank, seems ever so slightly better but im still looseing a lot of oil each time i use it.. Im thinking about uprating the breather system to a bailey one do you think this would help?
Old Jun 16, 2008 | 08:36 PM
LHD220Turbo's Avatar
LHD220Turbo
change your breather system to a set up like this, as quite frankly any set up which uses the kidney box is crap
Old Jun 16, 2008 | 08:39 PM
LHD220Turbo
also, maybe a long shot but i had a similar'ish problem and i couldnt figure out what it was. after much head scratching i decided to take the cam cover off; some idiot had put the cam cap studs in upside down which meant the nipple of the stud was pressing against the cam cover which stop it sealing properly.
worth a shot for the sake of 20 cam cover screws
edited to say: the cam cover studs should be input so the nipple of the stud goes into the head rather than the other way up.
having said all that i dont think it would cause oil to come up the dipstick, but worth a shot
Old Jun 17, 2008 | 09:03 AM
rossco22's Avatar
rossco22
Thanks for the info (LHD) think im gonna get a new breather system as per your pic hopefully this will work more effectively than the one i have on there already.... Fingers crossed this may
sort it!!!
Old Jun 18, 2008 | 06:31 AM
Aaroncast's Avatar
Aaroncast
-oil up the dipstick=to much crank case pressure right enough----------
THAT CEREAL BOX THING TABS!!!---------------I TRIED IT AND ALL THE CEREAL DROPPED OUT !!!!!-------BLOODY CO-CO POPS EVERYWHERE!!!!!!!!
Old Jun 18, 2008 | 11:55 AM
Daxcossie's Avatar
Daxcossie
Make sure you have not overfilled the oil aswell. In the Dax the engine is tilted forwards, whereas in the Sierra its slightly backwards. I needed to jack mine up into the correct position, fill oil to correct level, then lower back down and make a notch on the dipstick to indicate max.
Old Jun 18, 2008 | 05:33 PM
rossco22's Avatar
rossco22
Originally Posted by Daxcossie
Make sure you have not overfilled the oil aswell. In the Dax the engine is tilted forwards, whereas in the Sierra its slightly backwards. I needed to jack mine up into the correct position, fill oil to correct position, then lower back down and make a notch on the dipstick.
Ok thanks, i think its mounted fairly straight but ill have a closer inspection to see if this is the case ? Its so anoying having a new toy an not being able to use it....
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
16
Aug 14, 2015 06:13 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
