mfi to efi fuel pump
Old Jun 4, 2008 | 08:05 PM
siward's Avatar
siward
Default mfi to efi fuel pump
Hi All,
I am fitting a 2.0 zetec turbo engine into my van which had a 1.9 cvh turbo engine with mfi. I will be using fiesta turbo ofab management, Can i use the standard fuel pump and filter or will it need to be replaced?. Power should be around 250bhp
Any help would be apriciated.
Si
Old Jun 5, 2008 | 09:24 AM
siward's Avatar
siward
Also do i need to remove the fuel accumulator or wont it hurt to leave it in?
Old Jun 5, 2008 | 10:32 AM
JesseT's Avatar
JesseT
MFI pumps are generally more powerful than EFI pumps and MFI can be used on both. The accumulator shouldn't really be left in. It will cause trouble if your injectors leak even a little bit. The accumulator should bottom out at around 2bar pressure, so it won't really screw up the transient fuelling even though in theory the accumulator tries to maintain constant pressure and the EFI regulator tries to tune the pressure with MAP.
Old Jun 5, 2008 | 11:08 AM
siward's Avatar
siward
Thank you for the reply, I will leave the accumulator out then i think, Glad i hav'nt got to change the fuel pump, so should be nice and easy to sort out fuel pipes.
Si
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
