Escos Clutch problems
Old Jun 1, 2008 | 07:08 PM
Azrael's Avatar
Azrael
Default Escos Clutch problems
I have the car back on it's wheels but there is a problem with the clutch. I have had new AP Racing organic kit (from Mike R - thx Mike) fitted. I have standard clutch ratchet and original Ford cable. Anyway - even with pedal fully depressed you cannot shift into any gear when the car is running. What is even more strange when you start it in gear and drive the clutch is slipping!!!. Does anyone have any ideas? I have checked part numbers on the clutch driveplate and preassure plate and they are correct. I have the gearbox back out and all seams to be in order, does anyone have ideas or suggestions?
Old Jun 1, 2008 | 10:42 PM
hughy's Avatar
hughy
m8 not 100% correct on this but did you check or reset th self adjusting thing on th clutch padel!!
Old Jun 2, 2008 | 12:39 AM
Azrael's Avatar
Azrael
Yes sure. It can't make a clutch not disengage and slip at the same time though.
Old Jun 2, 2008 | 09:32 AM
Azrael's Avatar
Azrael
Not a single idea?
Old Jun 2, 2008 | 11:01 AM
LHD220Turbo's Avatar
LHD220Turbo
really stuck on this one; maybe send Mike a PM to see if he has any ideas?
Old Jun 2, 2008 | 11:30 AM
dojj's Avatar
dojj
Resident Wrestling Legend
sounds like the clutch isn't disengaging properly when you press the pedal
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I have heard of this problem before with another customer, who was convinced I had supplied him with the wrong parts .
From what I understand, the AP clutch has a lot more material on the drive plates than the original items, so it will not tolerate a stretched cable in any way shape or form. Also the ratchet has to be working exactly and be perfectly aligned.
After fiddling around with the cable and the ratchet, they eventually got the clutch to work, albeit with the clutch operating with only ½" travel from the floor. However, after a few months of use, the pedal travel increased nicely as the drive plate wore down and is now where it would normally be .
Obviously this is typical of these type of clutches and is why I always recommend hydraulic actutation. However, you could always try one of these instead if hydraulic is too expensive :
https://passionford.com/forum/showth...ht=new+product
Old Jun 2, 2008 | 04:37 PM
Azrael's Avatar
Azrael
Mike the problem is that even with the part that releases the clutch (I am not sure what it is called) pressed against the gearbox casing by hand the clutch is not fully disengaged and at the same time it's still slipping with pedal released.
Old Jun 2, 2008 | 04:38 PM
Azrael's Avatar
Azrael
Anyways Mike please send me an offer for hydraulic kit. Please rememeber that my car is LHD.
Old Jun 2, 2008 | 08:19 PM
kennyA's Avatar
kennyA
Hi Mike
If I join Jacob, what would be the price for 2 kits? (remember it needs to align with the clutch from Harvey).
yatta
May 21, 2016 10:31 PM
talon1
Sep 15, 2015 10:27 AM
Flateric_2002
Sep 15, 2015 08:41 AM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
