CV boot
Old May 28, 2008 | 08:11 PM
M4tty's Avatar
M4tty
Default CV boot
hi,
my cv boot gaitor has split and with the car being off the road it has had no use with it and now its is nearly impossible to move the wheel, takes 2 people to push the car on the flat.
So is it a question of cleaning it up refilling with grease and replacing the gaitor?
Or new whole CV joint?
It the drivers side outter on FRST if that makes a difference
Thanks
Old May 28, 2008 | 08:49 PM
groomers's Avatar
groomers
personally i would replace it but if you want try taking it apart and giving it a good clean and regrease
Old May 28, 2008 | 09:02 PM
M4tty's Avatar
M4tty
k mate ill have a look at it
suppose it would be better in the long run to replcae the lot
Old May 29, 2008 | 06:26 AM
Depends how bad the split was, how much grease it lost, a gaiter is often fine.
The car may just have rusted discs stopping it from being pushed easy, they all rust when left, even overnight if it rains!!
If you wet your finger and put it on a hot disc, it will hurt!!, but when water has been cooked seconds later you will see small brown spots of rust!
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
mk1turboestate
Dec 2, 2015 08:31 PM
chris m1
Sep 7, 2015 08:02 PM
