fitting kit for greys
Old May 25, 2008 | 02:30 PM
crash_ash's Avatar
crash_ash
Default fitting kit for greys
anyone got a photo or diagram of a grey injector correctly adapted for a cosworth?
Old May 25, 2008 | 02:42 PM
2001ode's Avatar
2001ode
Hi,
Is that you need ?
Regards.
Claude
Montage des 403 plan Ford MS
Old May 25, 2008 | 09:18 PM
crash_ash's Avatar
crash_ash
job done, thanks
Old Jun 5, 2013 | 11:46 AM
COSWORLD's Avatar
COSWORLD
Hello,
i have a fitting problem with my greys. the adaptor rings do not fit.
the inner diameter of the rings is 7,5 mm. and the diameter of the injectorpart the rings have to slide onto is 7,8 mm. so can you tell me whats wrong please? is it the wrong kit? i have it from burtonpower. or are there different grey injectors with different dimensions available? i have 0280150403, i think that should be correct. or is it an interference fit and the rings must be pressed on the injectors? can not believe that. 0,3 mm interference is way too much. i will destroy the injector when trying to force the rings on.
Old Jun 5, 2013 | 05:37 PM
Alvyn's Avatar
Alvyn
when fitting greys 403's on the Cosworth do remember to leave the cap of the bottom of the injector
Old Jun 5, 2013 | 05:44 PM
COSWORLD's Avatar
COSWORLD
Hello,
i am not talking about the BOTTOM (you mean the blue plastic "bushing" i guess). i know that this blue plastic shroud or bushing or whatever must be removed
i am talking about the TOP. and there is nothing to leave. like i said. the top cylindrical part of the injector has 7,8 mm diameter, and the adaptor rings have 7,5. that does not work without massive force. will i have to drill out the rings? i don`t thinks so.
Old Jun 5, 2013 | 06:05 PM
Alvyn's Avatar
Alvyn
Originally Posted by COSWORLD
Hello,
I was talking to peeps who fit them in general mate! and by the sounds of it your rubber seals are the wrong ones you been supplied and nope to the drilling out tbh!
Old Jun 5, 2013 | 07:17 PM
COSWORLD's Avatar
COSWORLD
if the rubber seals are wrong it is not that big problem, because they are elastic. steelrings are not. i also think that drilling out is rubbish.
so if there are no different grey injectors with different dimensions, the only solution is a wrong fitting kit...
manuel boeckx
13
Oct 3, 2015 02:29 PM
Porplus12
Sep 10, 2015 07:20 PM
john_3.0s
Aug 16, 2015 06:40 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
