T34 turbo Identification
Old May 22, 2008 | 07:02 PM
jpblue's Avatar
jpblue
Default T34 turbo Identification
Just recieved a turbo from a seller on Ebay. He claimed it is a T34. How do I tell firstly that it is a T34 and secondly, if it isnt, what sort of turbo it is
Written on it is:
Compressor: Garrett A/R .42 BC1
Exhaust: A/R -4 DH4 ?OE M4 DH56 NI
Is there something I can measure to help?
Hope you can help before I have to leave feedback or ask for my money back
Cheers guys
Justin P
Old May 22, 2008 | 07:10 PM
BigErn's Avatar
BigErn
any pics?
Old May 22, 2008 | 07:22 PM
jpblue's Avatar
jpblue
how about these?
hope they help
what are you looking for, whats the visual tell tale
Old May 22, 2008 | 07:24 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
thats off a cosworth 4x4 t3 turbo
BigErn's Avatar
BigErn
Looks very T3 to me, thought the numbers sounded 4x4 T3
Old May 22, 2008 | 07:25 PM
BigErn's Avatar
BigErn
You beat me to it
Old May 22, 2008 | 07:32 PM
jpblue's Avatar
jpblue
so what the difference between this and a t34/t35 Im guessing its going back to the seller and bad feedback to ensue as it was described as a t34
Old May 22, 2008 | 07:35 PM
G2RSR's Avatar
G2RSR
Bodybuilding
pics of a t34
Old May 22, 2008 | 07:40 PM
jpblue's Avatar
jpblue
thanks for your help guys,
the big differences look to be the compressor housing would that be the main difference
Before I tell the guy to stick it I had better know what Im talking about
Old May 22, 2008 | 07:48 PM
LHD220Turbo's Avatar
LHD220Turbo
the compressor housing "looks" too small to be a t34 IMO
here's my t34.55
Old May 23, 2008 | 07:42 AM
It COULD be a modded T3 to T34 spec, though!!
I have a T3 "looking" turbo but is T34 inside, as you can see from the piccie the T34 inlet gets MASSIVELY narrower at the trim wheel entry end, no larger than a T3 infact, and that is why I had mine machined out inside the comp housing to accomodate a T34 trim wheel.
I don't of course know whether this is the case above, just that it could be.
But externally certainly is a TO3/T3.
Old May 23, 2008 | 08:39 AM
jpblue's Avatar
jpblue
what measurements could I take to determine what it is, or is it the shape of the compressore wheel etc.
Correct me if Im wrong please.
The T3, T34/35 T4 all use the same bearing core and the only difference is the housing sizes and compressor/impellor wheels. Thus as anything I buy is going to need a rebuild should I just put a t34/t4 front on this turbo and be done with it. or should I match the exhaust size or at least .48 size rather than the .4 or .42 it may be. or just posrt it back to the seller and demand my cash back!!
Hope thats self explanatory.
any ideas,
thanks again for your input.
Cheers,
Justin P
Old May 23, 2008 | 08:54 AM
Up to you what you do but,
YES same bearing core on T3/(34/35)/T4.
Assuming you have your old turbo, I would send that for a rebuild and get your money back.
You need to spec the turbo to the engine, but T34 will work with a std engine or modded one, but depending on what has been done ? a different one may be more suited.
I use Craig/Andy at the TURBOCENTRE 01924 404112, good honest lads, do all the mods as well.
Old May 23, 2008 | 11:51 AM
LHD220Turbo
personally i'd sling it back to the seller as item not described; the compressor housing is not a t34. Unless he said it was a t34 internals with a t3 housing i'd say its item not as described.
Assuming you still have your original t3, i'd send that away to get modded to a t34 spec and that way it will have a rebuild as such....its better than buying something off ebay which could be in need of a rebuild anyway
if you dont have your original, PM me
Old Dec 3, 2009 | 05:40 PM
mattman1234's Avatar
mattman1234
i have bought a t34 turbo
it has a .48 exhaust and .60 compressor,does this sound right, i read above the t34 has a .55 compressor housing,what is the actual difference
thanks matt
Old Dec 3, 2009 | 05:45 PM
LHD220Turbo
thanks matt
t34 normally come with 3 exhaust housing sizes
.48
.55
.63
Rsmat
63
Sep 25, 2015 12:11 PM
28
Sep 8, 2015 07:10 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
