pinto cam
Old May 19, 2008 | 04:27 PM
juffer's Avatar
juffer
Default pinto cam
Hi,
I cracked a piston in my pinto so i swoped it with another pinto engine which has a recon head. I have removed the piper camshaft which i was running from my old engine and put it in my new engine. I cant get the cam to time up in the new engine. The difference between the two engines as far as i can see is the numbers on the block. the old one was 205 and the new one is 165.
any help will be great.
Old May 19, 2008 | 04:50 PM
165 is transit, will time up exactly the same.
What precisely is the problem ?
chowfornow
14
Jan 5, 2019 09:01 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
20/20 vision
Sep 29, 2015 11:27 AM
