Lost 0.5 Bar somewhere!
Old May 18, 2008 | 08:08 PM
Dannyf1380's Avatar
Dannyf1380
Default Lost 0.5 Bar somewhere!
I'm relatively new to cossie ownership, When I first got my cossie (stage 3) it would peak at just over 1.5 bar and hold around 1.3ish - Now it barely peaks over 1 Bar.
Is there anything that could cause this to happen?
Old May 19, 2008 | 04:11 AM
The weather, or a duff/weak actuator, wear in the turbo.
Old May 19, 2008 | 05:58 AM
KSA-Cossie's Avatar
KSA-Cossie
As above.
Old May 19, 2008 | 08:16 AM
Dannyf1380's Avatar
Dannyf1380
Could be the actuator...
Admittedly I have tried to turn the boost up by winding the actuator back although this doesnt seem to make a difference whatever way I turn it?
Old May 19, 2008 | 02:42 PM
It won't if it is knackered, could be the seat on the wastegate getting worn and leaking as well, VERY common.
Old May 19, 2008 | 02:55 PM
JamesH's Avatar
JamesH
Leak in vacuum hoses possible
Old May 19, 2008 | 03:04 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Be careful tinkering with boost, more than 1.5bar on a std fuel pump, original pump wiring and standard intercooler is probably asking for trouble.
I run an uprated fuel pump, wiring, 4x4 intercooler and T34 on our 2wd cossie. We've left boost at 15psi held or thereabouts to be safe because detonation occurs on a warm day, hot engine if we increase it much beyond that !
Unless you know what you're doing I'd make sure you have this boost issue checked by a pro, or, we could soon be trying to help you out through your first YB engine rebuild
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
The Youth.
Sep 30, 2015 09:59 PM
deathrider666
Sep 28, 2015 06:12 PM
