understeer or just my imagination??
Old Oct 25, 2004 | 03:39 PM
rapidcossie's Avatar
rapidcossie
Default understeer or just my imagination??
alrighty there folks!
quick question for you all...
i have just had my ball joints/bottom arm assembly changed on my 2wd saf.
I now think the car understeers badly in the wet where is was ok before?
would changing these parts effect anything camber/tracking wise that would cause bad understeer??
OR
is it just my imagination or something else ??
cheers!
Old Oct 26, 2004 | 04:25 PM
rapidcossie
thought someone on here would have known this?
Old Nov 14, 2004 | 12:39 PM
rapidcossie
up
Old Nov 14, 2004 | 01:37 PM
Azrael's Avatar
Azrael
Maybe you schould try checking suspension geometry, generally each time to you something withe suspenntion it changes slightly. Or aybe it's just time to set it right.
Old Nov 15, 2004 | 07:24 AM
foreigneRS's Avatar
foreigneRS
Testing the future
changing them will change the toe setting slightly (also known as the tracking). this can dramatically affect the andling. get it set up back to std spec, best on a 4 wheel laser alignment rig, rather than the old style gauges.
Old Nov 15, 2004 | 01:55 PM
Azrael's Avatar
Azrael
Anybody still using that??
Old Nov 15, 2004 | 07:29 PM
Guinnless's Avatar
Guinnless
IIRC Zoo use Dunlop gauges. As do other motorsport places.
Oh and I've got a set too
Old Nov 15, 2004 | 10:58 PM
Azrael's Avatar
Azrael
You know - I know people who can set geometry with two curtain hangers and a stick when doing quick service to rally/rallycross car, but that's not the point
Old Nov 16, 2004 | 02:18 PM
Guinnless's Avatar
Guinnless
Is the point that 'anybody' can use the laser setup?
Old Nov 16, 2004 | 03:49 PM
Azrael's Avatar
Azrael
I know polaces where they got best possible laser insruments and set geometry badly and places with older ones where they know how to use it.
CrOwSoN15
Sep 14, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Seanyfarrell
Aug 14, 2015 11:37 PM
rapidcossie
Oct 16, 2004 01:36 PM
