Fiesta 1.25 Hesitation Problem
Old Apr 30, 2008 | 09:35 AM
johnhara1's Avatar
johnhara1
Default Fiesta 1.25 Hesitation Problem
Hi, im new.
I bought a little run around fiesta 1.25 16v Zetec last night.
When you accelerate the car seems to miss\hold back for a split second before it goes. It does this throughout the rev range, it's driveable but very annoying as the car should be so much quicker.
Also when it got to 4000revs it was almost like it had hit the limiter, just went flat. Then it's fine, then it's not again.
It doesnt stall or cut out but at idle the revs tinker very slightly up and down.
I will be changing the fuel filter tonight and giving it an oil service. Any ideas what the hesitation problem could be?
Someone suggested mis-aligned throttle sensor?
What about cleaning the MAF with carb cleaner?
Old Apr 30, 2008 | 10:46 AM
PewteRS's Avatar
PewteRS
Mine does this at 4500 revs and i had a mate who works for Ford check it out he told me to get new leads and a new coil pack.
I've not done it yet coz i never rev it that high
Old Apr 30, 2008 | 11:00 AM
johnhara1's Avatar
johnhara1
Mine does it throughout the rev range, its like its being choked.
Old Apr 30, 2008 | 11:21 AM
johnhara1's Avatar
johnhara1
Got replacement coil and leads in post. Ł11 delivered off ebay.
Ill try this 1st, thanks.
Old Apr 30, 2008 | 11:27 PM
johnhara1's Avatar
johnhara1
New plugs have cured the hestitation problem.
Now it just gets to 4000rpm and holds back loads.
Old May 1, 2008 | 07:26 AM
instain's Avatar
instain
get sum 1 to rev it hard and hold your hand close to the exhaust in the line of the gasses if bits are flying out your exhaust (usually hot bits that make ya jump) the cat is knackered
Old May 1, 2008 | 08:32 AM
johnhara1's Avatar
johnhara1
Thanks ill try that mate.
Old May 1, 2008 | 10:42 PM
johnhara1's Avatar
johnhara1
FIXED!!
Took the MAF sensor off and cleaned the shit off the element with a cotton bud and carb cleaner.
No more holding back, from 4000rpm it pulls hard.
Thanks for the help.
Old Jun 13, 2010 | 12:02 PM
berg81's Avatar
berg81
Hi,
Could anyone point me in the right direction for the MAF??
I think thats whats wrong with mine but I have no idea where it is.
Simon
Old Jun 13, 2010 | 02:18 PM
Maf will be between air box and inlet somewhere, should see a multiplug going to it, they are an alloy body with a juby clip either side where the trunking is.
rex647
Mar 6, 2022 06:20 AM
Marino
Sep 12, 2015 11:10 AM
28
Sep 8, 2015 07:10 PM
BRAM
Sep 8, 2015 07:11 AM
routemaster
Sep 7, 2015 05:27 PM
