S2 rst goes really lean under boost.. please help
Old Apr 16, 2008 | 05:57 PM
Antti O's Avatar
Antti O
Default S2 rst goes really lean under boost.. please help
Hi!
I have 89 s2 rs turbo and just got plates today.
Car runs quite ok when driving without no boost under 0 psi.
When i press the gas and the boost starts to rise the car goes so lean that the normal afr meter goes off the range lean so i stop immediately the boost rise. I can feel the car does not run correctly under boost.
Coupe of checks i did made:
-Ignition advance is correct
-Gas return line removed and measured in bottle, i think fuel pump ok.
-New spark plugs
-All hoses ok, no leaks.
Any ideas?
The car is stock except kent 35 cam and 2.5" free flow exhaust, standard air filter etc.
Old Apr 16, 2008 | 07:29 PM
3doorcozmess's Avatar
3doorcozmess
sound like the fuel pressure regulater is fucked its on the side of the metering unit little black or grey box
Old Apr 16, 2008 | 08:49 PM
gup's Avatar
gup
or your tps senser is not set correctly
Old Apr 17, 2008 | 05:02 AM
Antti O's Avatar
Antti O
Okay thanks for the replys.. : )
I try to get another ke-jet fuel distributor to test if will help, i will go ms-efi later this year so i i want to put car working as minimal cost as possible. I did read somewhere there is some adjustment screw in distributor under the fuel pressure regulator? Should i try adjust it first, or replace directly whole ke-jet fuel distributor unit?
Imagine what would been happen if i dont have afr meter
ps. If you have 100% sure working fuel distributor unit pm for me
Old Apr 18, 2008 | 03:16 PM
3doorcozmess
u can do it ur self but i think it only needs a little turn not even 1/4turn
Old Apr 20, 2008 | 05:40 PM
Antti O's Avatar
Antti O
i did change the fuel distributor unit and the problem is now gone.
Old Apr 20, 2008 | 09:52 PM
3doorcozmess
do u mean the little box on the side of the metering unit, fuel pressure regulator
Old Apr 21, 2008 | 02:31 PM
Antti O's Avatar
Antti O
I mean the whole ke-jetronic fuel distributor
http://www.southportfuelinjection.co...c_fueldist.jpg
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
Billy_RS
Sep 13, 2015 04:17 PM
