Stalling Small Turbo Escort Cossie - Desperate!
Hi
I have a small turbo Escort Cossie and it's really starting to frustrate me. When it gets warmed up it stalls after being revved/ pulling up traffic lights junctions etc. The revs dip really low and it often cuts out.
We have changed the Idle Speed Control Valve & found it didn't have speed sensor so fitted one along with a new speedo cable. I took it to a rolling road and they said it was running lean and were sure it was the MAP sensor so changed that, no good. It has been on diagnostics at Bristol Street Ford & an independenant garage and there are no faults. I also changed the fuel filter.
We are looking at changing the MAS sensor & Throttle position sensor next but my wallet is not bottomless. My friend that works for Ford suggested it could be the timming out slightly after a cam belt change but that was Ocober 2006 & it was off the road until about June 2007 & I never noticed the problem until the August.
Any help or advice appreciated.
I had similar with mine except it didnt stall but revs went well low.
Interpro thornbury have been working on mine as the car was also running lean when put on boost. the answer is my standard ecu is knackered and at the mo they are fitting with the latest OMEX system, quite costly though, but will be worth it, should have it back next week. if it resolves my probs will let u know
rgds nik
rgds nik
Billy_RS
16
Oct 11, 2025 09:41 PM
