Steering judder under breaking.
Old Mar 26, 2008 | 03:53 PM
S2Steve's Avatar
S2Steve
Default Steering judder under breaking.
I was missing the caliper/pad retaining clip, and thought it would be this, but when fitted it made no difference. Its Cossie breaks on my S2, is it likely to be warped discs, or are there other reasons for this?
Old Mar 26, 2008 | 05:43 PM
cozmeister's Avatar
cozmeister
More boost Igor!
4 pots or single pots?
Most likely to be warped discs - it's a feature that Ford didn't put in the sales brochure
Or bushes.
Old Mar 26, 2008 | 05:53 PM
NUTS RuS's Avatar
NUTS RuS
Is it speed related ?
More speed more judder or will it do it the same at low speeds too ?
Old Mar 26, 2008 | 06:10 PM
S2Steve's Avatar
S2Steve
Not sure about 2pot or 4pot, all i know is they are standard cossie ones, possibly 2wd discs and 4x4 calipers. It does it at all speeds, but is much more violent at higher speeds, i.e. coming off the motorway etc.
Old Mar 26, 2008 | 06:41 PM
The most common conversion is 2wd discs with 4wd calipers.
As said very common to be warped, I just change my discs every other year with new pads.
Old Mar 26, 2008 | 06:45 PM
NUTS RuS's Avatar
NUTS RuS
Did you fit new pads ?
Old Mar 26, 2008 | 06:54 PM
S2Steve's Avatar
S2Steve
I haven't touched them since I had the car apart from fitting the new retaining clip to the front passenger caliper
Mile30
69
May 13, 2017 08:44 PM
tankybaby66
Feb 6, 2016 02:24 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
martynhomer01
14
Sep 23, 2015 12:23 AM
