P100 engine change....
Old Mar 21, 2008 | 01:23 PM
cosrep's Avatar
cosrep
Default P100 engine change....
Hi,
I have the opertunity to buy a P100 1.8TD for next to nothing because the engine is F**Ked, the rest if the mechanicals and the shell have been maintained very well. My question is this I have a low milage (35K) mondeo 1.8TD Engine just lying around as you do and as far as I know there basically the same engine. Would it be a reasonably straight forward swap considering I'd be changing from transverse to inline?
Old Mar 21, 2008 | 02:04 PM
B19LRW's Avatar
B19LRW
Its Broken.....
AFAIK they are the same!
Old Mar 21, 2008 | 05:33 PM
cosrep's Avatar
cosrep
I'm talking about in relation to wiring etc for example the P100 didn't use a air flow meter or an immobiliser...
Old May 18, 2012 | 09:47 PM
johnhonda800kk's Avatar
johnhonda800kk
as far as i know you might have to use the flywheel and spigot bearing of the p100 and use the diesel pump to of the p100 which only needs the 12 volt supply to run it advoid having to use the mondeos ecu and all that
Billy_RS
16
Oct 11, 2025 09:41 PM
hopper350
Sep 4, 2015 12:53 AM
