zvh
Old Jan 26, 2008 | 08:41 PM
fifty's Avatar
fifty
Default zvh
hello all . Just wondering if a 1800 zetec engine from a 03 focus would be ok to use some one told me the later engines had a ally block instead is this true and can i use sump and flywheel many thanks in advance fifty
Old Jan 28, 2008 | 06:54 AM
NATH-RSZT's Avatar
NATH-RSZT
You can use the later block but you will have problams fitting the water pump as the hole on the side of a later zetec for the water pump only has a 40mm hole compared to the old zetec that has a massive hole 90mm i think. NO the block isnt ally . you can use a sump from the older zetecs also. you will need an escort or fiesta sump and oil pipe.
Hope this helps
Old Jan 28, 2008 | 12:38 PM
fifty's Avatar
fifty
Thanx for your reply nath . if i got to swap sump and pick up pipe may as well get a mk1 zetec from an escort or fez then just got to keep lookin ha ha
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
Del gsxr
Sep 19, 2015 05:53 PM
