RST metering unit help....
Old Oct 6, 2003 | 07:56 PM
SteveB's Avatar
SteveB
Default RST metering unit help....
Right got a perminant missfire .......
Cylinders 1,2 and 4 are 100% fine
Fault is on number 3 cylinder....
Disconnect HT lead makes no difference.
Got a good spark.
Got fuel (had injector out while cranking and ge ta good spray of fuel)
Got good compression.
Rockers are both ok on head.
But doesn't fire on that cylinder
any help much apreciated
Old Oct 6, 2003 | 07:59 PM
Toe Knee's Avatar
Toe Knee
Sounds like my cossie when a head i got had a problem!! Turned out when the bloke i bought it off got it checked there were 2 loose valve guides in it!!! Which was making it loose compression and only run on 3 cylinders.
Old Oct 6, 2003 | 08:31 PM
L33 BYT's Avatar
L33 BYT
U checked it aint some thing silly like the lead or spark plug. you never know u may be lucky.
Old Oct 6, 2003 | 08:53 PM
SteveB's Avatar
SteveB
Checked them
Old Oct 6, 2003 | 09:11 PM
Rob M666SCC's Avatar
Rob M666SCC
Worth checking the cam............even if you have good compression the cam may be fooked
Old Oct 7, 2003 | 11:51 AM
flashpoint's Avatar
flashpoint
How did the fault start, was it ok one day and then just appeared, or was I after hard abuse, or engine rebuild,etc.
CheeRS
Steve
Old Oct 7, 2003 | 05:45 PM
dave green's Avatar
dave green
Air Leak ? test engine comprestions.
Old Oct 7, 2003 | 06:08 PM
L33 BYT's Avatar
L33 BYT
mmm. Does the miss fire clear when you rev it??
Old Oct 7, 2003 | 07:45 PM
SteveB's Avatar
SteveB
Compression all fine.
Misfire all the time.
Bought the car like it.
Just doen't do anything on cylinder number 3 even tho it has fuel and a spark....weird
Old Oct 7, 2003 | 07:46 PM
SteveB's Avatar
SteveB
also .....
No air leaks and cam is fine
Old Oct 7, 2003 | 07:55 PM
L33 BYT's Avatar
L33 BYT
I think your gonna have to have the head of just to check. Ok it'll cost ya in bits. but u have done the things which I would try. Ok your getting a good compression, but if there is fuel being dumped into the bore and for some reason it is not firing, then the fuel will increase the figures you are given on the compression gauge.
Old Oct 7, 2003 | 09:45 PM
RScrew69's Avatar
RScrew69
bent or burnt valve
Old Oct 8, 2003 | 08:15 AM
Stu @ M Developments's Avatar
PassionFords Creator
Does it rattle a bit Steve? If so, swop the followers from No:1 to No:3, they may be knackered.
Old Oct 8, 2003 | 01:07 PM
RScrew69's Avatar
RScrew69
have the followers still ot oil in them if the car hasn't been run for a long time, try squeezing the oil out of them and check if there worn underneath. if there full of oil have pressed so the oil is all out, so they will fil up when u start, if there already full sometimes they have difficulty as stu said if there worn items.
cheers
Old Oct 8, 2003 | 02:18 PM
RichardPON's Avatar
RichardPON
Book it in we will have a look for ya
Old Oct 8, 2003 | 02:30 PM
SteveB's Avatar
SteveB
Sorted now guys......Cheers to Karl Norris for the hand while he was here picking up some of my Cossie bits ......
Old Oct 8, 2003 | 06:01 PM
dave green's Avatar
dave green
Tell us waut the problem was then.
Old Oct 9, 2003 | 11:17 AM
SteveB's Avatar
SteveB
metering head
A.t.p
Oct 23, 2015 07:54 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Steve Escos
Oct 1, 2015 06:57 AM
A.t.p
Sep 29, 2015 05:04 PM
