WHY DOSE A COSSIE ENGINE
Old Oct 14, 2004 | 06:22 PM
dave green's Avatar
dave green
Default WHY DOSE A COSSIE ENGINE
why dose a cossie engine always melt number two piston,
is it the design of the inlet manifold or what.
anybody got any idears
Dave
Old Oct 14, 2004 | 07:36 PM
DazC's Avatar
DazC
It's number 3 that is the common melted piston due to the design of the plenum elbow....
Then number 2....
Old Oct 14, 2004 | 08:39 PM
dave green's Avatar
dave green
as you say its allways two or three. mine just did number two. and was told feul pump was two blame.
Old Oct 15, 2004 | 08:39 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i would get the injectors flow tested before running it again as well. fuel supply problems of one type or another can cause this failure, either thepump or the injector not flowing enough fuel to match the requirement from the air mass.
number 3 tends to get slightly more air than the others, so fit the injector that flows the most to that cylinder so that when the average AFR is checked with a lambda sensor you have minimised the possibility of no. 3 running leaner (and hence hotter) than the rest.
Old Oct 15, 2004 | 10:34 AM
Baby blĺ's Avatar
Baby blĺ
Hello guys.
How far do you go before replacing OE fuelpump.
People here in Sweden burns piston like a barbecue party
My idea was that fuelpump wear was cause of concern here.
Its a interesting subject
Old Oct 15, 2004 | 02:56 PM
Dave Henshall's Avatar
Dave Henshall
for the escos, use the walbro 255l/h fuel pump, exact swap for the original one and only around 100 sheets
cossirob
Aug 29, 2015 03:23 PM
Gadget
Aug 26, 2015 01:02 AM
marky_g
Aug 19, 2015 11:46 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
lockie
Jul 31, 2015 10:03 PM
