weber guides
Old Dec 24, 2007 | 07:15 PM
mk1trb's Avatar
mk1trb
Boost Junkie
Default weber guides
anyone know how to set up a weber 32/34 dtml carb? cant get the bloody thing torun right with the chokes fully open, jus splutters on low throttle doin me nut in
thanx in advance
Old Dec 25, 2007 | 07:53 AM
Is the car modded ?
If std then it sounds like it is VERY lean, base nsetting for screw is normally around 1 1/2 turns out from fully in, as a starting point.
What car or the correct model number ?
Old Dec 25, 2007 | 10:25 AM
mk1trb's Avatar
mk1trb
Boost Junkie
its a 1.9 cvh, big valve head, piper 285 cam with vernier set to 2 degrees advance, its a 32/34 dtml carb, think its off a 1.8 cvh sierra, if i have the chokes open when warm it splutters at low speeds and is fine flat out, but if i close the choke 2/3rds then it fine low speeds but looses full throttle power?????
Old Dec 25, 2007 | 01:17 PM
mk1trb's Avatar
mk1trb
Boost Junkie
right i can get ok driving with the choke fully open if i wind the mixture almost all the way out, dizzy is set smack in the middle or it pinks, cam pully says 2 marks to advance, she use alot of fuel like this though, its ok if i have the choke 2/3rds closed and the mixture half a turn out from closed????
Old Dec 25, 2007 | 04:05 PM
All the 1800 sierra's used PIERBURG 2E3, manuals and auto's.
I can't find any listing for choke sizes of 32/34, can you put up a piccie, or get full number off the base of carb ?
Old Dec 25, 2007 | 05:12 PM
mk1trb's Avatar
mk1trb
Boost Junkie
pictures uploading as i speak, right the codes on the base were 32 34 dmtlo space 326 6
on the little mettle plate attached to the car they are 15419 then 015 7 under that
Old Dec 25, 2007 | 07:17 PM
I have looked in me book of ford carbs for 78-91, it is not listed, but sure I have heard of it.
I seem to remember it as a later xr2 carb, with vac secondary, but might be confusing it!!
The only advice I could give is maybe speak to RON KIDDEL, at the carb centre 0208 348 4218.
It will almost defo require rejetting due to mods so might be best just to book it in somewhere.
Old Dec 25, 2007 | 07:23 PM
My buddy just rang me after seeing thread about this carb.
It was offered as a replacement carb on various cars to replace the PIERBURG 2E3,(1800 sierra!!) and is fitted on anything from 2.5 landrover to 1.3 vauxhall/vw/bmw etc etc.
By all accounts it is a very good carb, as I say used in Weber's carb replacement kits, and there was me remembering a xr2!!
Old Dec 25, 2007 | 08:04 PM
mk1trb's Avatar
mk1trb
Boost Junkie
top job fella, think i'll get it booked in with my local carb man, he'll sort it
thnax mate
Old Dec 25, 2007 | 08:32 PM
I don't know where abouts in Suffolk you are, but I THINK LORVEN in Ipswich do carbs, and are ok.
Old Dec 26, 2007 | 01:14 AM
mk1trb's Avatar
mk1trb
Boost Junkie
no mate, lps shut down few weeks bk, i'll go t and m's in colchester i rekon
Old Dec 26, 2007 | 06:44 AM
LPS shut down, that's a shame as they had some good buys there.
Who are t+m's ?
Old Dec 26, 2007 | 11:58 AM
mk1trb's Avatar
mk1trb
Boost Junkie
there a place in colchester a mate of mine uses, he got a carbed nova and they pulled 185bhp out of it, my mate wiv mini's uses him too, there on the hythe industrial estate in colchester.
Old Dec 26, 2007 | 04:37 PM
Nice to know they are a dying breed due to everyone using FI now!!
thanks,
Old Dec 26, 2007 | 10:44 PM
mk1trb's Avatar
mk1trb
Boost Junkie
hes awsome with turbo's too fella, but he's oldskool and can tune a carb'd motor and it'll never give you any problems
Old Dec 27, 2007 | 04:22 AM
Luckily, I live less than 1/2 mile from EMERALD, and going Emerald next month as well, can't wait, get rid of the weber marreli!!
Old Dec 27, 2007 | 03:56 PM
mk1trb's Avatar
mk1trb
Boost Junkie
i had loads of problems with cossie managment, there an arse, after market is the way forward,
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
sridgett
Oct 1, 2015 07:30 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
RS-Rikki
Sep 21, 2015 07:27 AM
coscor86
Sep 20, 2015 01:21 PM
