Series 1 RS Turbo Starting problems
Old Dec 17, 2007 | 12:20 PM
Bigjohn's Avatar
Bigjohn
Default Series 1 RS Turbo Starting problems
Hi folks my car has been laid up for a while and I got the starter done up as it was sticking.The problem now is the cars starts ok when cold but as soon as it warms up a bit it wont start, its turns over with a heavy sound then the starter starts making noise like the bendix is not engaging the flywheel properly. Once cold everything is once again fine?
John
Old Dec 18, 2007 | 07:29 AM
originalcabbie's Avatar
originalcabbie
I tend to have the same problem. There are a number of things that you can do.
1) heat shield the starter motor to try and reduce the temps.
2) put an additonal switched line to the starter solenoid from the battery.
Apart from that there aint much!
Old Dec 18, 2007 | 02:49 PM
Bigjohn's Avatar
Bigjohn
Took the starter out to be redone and discovered the guy hadnt tightened the two bolts holding the starter together, tightened them up and away she went.
John
Old Dec 20, 2007 | 08:06 PM
primedog's Avatar
primedog
get a diesel starter moter. im buildin a series1 and get loads of advice from a m8 whos got an s2, he has neva had a problem startin wen hot after a thrashin. on other hand another m8 was raggin his s2 then it cut out, wudnt start. i had 2 giv him a bloody push n i was knackered jus finished football.
Billy_RS
16
Oct 11, 2025 09:41 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
adriansaleem
Aug 1, 2015 09:28 PM
