RS Turbo overfueling
Old Dec 14, 2007 | 11:43 AM
MikeeB's Avatar
MikeeB
Default RS Turbo overfueling
Hi again peeps,
my bro inlaw has fitted a turbo engine to his convertible escort, we cut in the whole front of the loom from the turbo so nothing is missing. But now the engine is running it appears to be overfuelling on 2 cylinders, from memory i thing it is 2 and 3. Is there anything common that would cause this to happen or is it possibly a more in depth problem?
Cheers in advance again
Mike
Old Dec 17, 2007 | 07:48 PM
MikeeB's Avatar
MikeeB
any one?????
Old Dec 18, 2007 | 07:50 AM
originalcabbie's Avatar
originalcabbie
if it is on an MFI setup, the two injectors could be blocked, the metering head could be malfunctioning.
if it is EFI, not a clue!
Old Dec 27, 2007 | 01:45 PM
MikeeB's Avatar
MikeeB
Thankyou, the car is running MFI by the way
Old Dec 27, 2007 | 04:31 PM
originalcabbie
try swapping over the pipes and see if the problem moves cylinder. if so its a metering head fault if not its an injector fault. did it have this before?
Old Sep 4, 2011 | 01:21 AM
escortrscab's Avatar
escortrscab
ive got a similary problem with chucking black smoke out un burn fuel overfueling have swaped tps, injecter pipes fuel pump metering unit any suggestions any 1 ????????
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
