Zetec turbo
Old Dec 1, 2007 | 10:22 AM
Phil2002's Avatar
Phil2002
Default Zetec turbo
Hi all
if your in the procces of building a zetec turbo i'm doing a blog on it to help out. Please take a lokk and let me no what you think also if you have any usefull info please post it
http://diyzt.blogspot.com/
Old Dec 1, 2007 | 01:17 PM
JesseT's Avatar
JesseT
You wont be able to place the throttle body how you've done if you're using the standard brake servo and master cylinder.
Old Dec 1, 2007 | 04:55 PM
Phil2002's Avatar
Phil2002
Intresting. Will it hit the master cylinder it self i was under the impression i would only have to re locate the resevoir.
Old Dec 2, 2007 | 11:18 AM
JesseT's Avatar
JesseT
That might do it as well. I haven't even though about the possibility of relocating the reservoir only.
Old Dec 2, 2007 | 07:14 PM
pdfbt40's Avatar
pdfbt40
There are a lot more quite important differences between the Series 2 & 3 engines. Not only that, there are significant differences between the American Series 3 and the European engines.
Where you have currently got to, this is significant in that you've already purchased pistons.
The basic Series 2 & 3 engines have (well documented) differences in conrod length, piston compression height and pin diameter. What is less well recorded, but probably of less interest to you, are that these are also different in both the ST170 and RS (Turbo) Focus Series 3 based engines.
What is documented, but most people miss, is that the American engines also have another set of dimensions. In general, you can fit matching sets of rod/piston in either Series 2/3 blocks, but for example your pistons will not fit on European rods.
So you're going to be looking at another VAT bill, but even with that, with the current $/Ł rate everything is still cheap.
Good Luck.
Old Dec 3, 2007 | 05:50 PM
Phil2002's Avatar
Phil2002
I didn't know that
before i bought the pistons i did ask them if they would be ok for a english 2.0 zetec they said yes we'll have to see, aint stripped the bottom end yet that tommors task so i'll see if they fit.
Thanks for the advise.
Phil
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
