Help any one have omex 550
Old Nov 29, 2007 | 10:21 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default Help any one have omex 550
Having prob getting 2l 16v zetec turbo running. Have got rover 820 inlet. Sabb 2.3 turbo injectors red ones. Focus central pistons. Eagle rods. Stage 3 t3. 8.2.1 compression with cosmetic head gasket 1mm. And a uprated escort cossie fuel pump. All this in a j plate escort mk5 cab. Problem is it starts on button but will only run 4 15 seconds then cut out. But restarts straight away. If u touch throttle it cuts out as well. Please help lossing temper with it. Cheers.
Old Nov 30, 2007 | 06:28 PM
Wardy257's Avatar
Wardy257
Double check all the wiring. Have you calibrated the sensors to the ECU?
Old Nov 30, 2007 | 07:56 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Na how u do that
Old Nov 30, 2007 | 07:57 PM
DazC's Avatar
DazC
That could be an issue with the map or sensor calibration...
Are the injectors low impedance? IIRC Omex can only run high impedance injectors.
Old Nov 30, 2007 | 08:43 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Injectors ok say omex and previous posts on here. No balas resisters needed. How u do this calibratiion stuff
Old Nov 30, 2007 | 09:31 PM
Wardy257's Avatar
Wardy257
Calibration depends on the ECU. It should say in the manuel from Omex.
Old Dec 1, 2007 | 02:30 PM
mappindude's Avatar
mappindude
have you got map for load ticked (in options?)
Old Dec 1, 2007 | 07:34 PM
ASHCOSSIE's Avatar
ASHCOSSIE
not sure will check what that do
Old Dec 1, 2007 | 07:40 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Old Dec 1, 2007 | 07:41 PM
ASHCOSSIE's Avatar
ASHCOSSIE
just checked and it on
Old Dec 1, 2007 | 10:14 PM
wide ka's Avatar
wide ka
call omex, very helpfull sorted all my issues out straight away over the phone
Old Dec 1, 2007 | 10:26 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Done that and they say it need a map done taliord 4 engine. Any one here do base maps or even running in maps. Am near heathrow a place called shepperton. Had a guy but he nightmear to get hold off.
Old Dec 18, 2007 | 09:15 PM
mappindude's Avatar
mappindude
make sure TPS raw value reads about 4 lower than actual value
eg, tps raw reads 30 then set tps min as 26.
This should give a throttle reading of 1 in parameters.
Escortdriver1
Nov 1, 2015 07:55 PM
dombanks
Sep 21, 2015 08:38 PM
jay030787
Sep 18, 2015 07:34 PM
Tank Mike
Sep 14, 2015 03:56 PM
ekjim
Aug 17, 2015 08:57 PM
