Series 3 Zetec
The simple answer is no, but only some of it.
If your question is only about rods & pistons, then the conrod length, compression height and pin diameter are different. However (as with fitting Series 2 European parts, as Performance Ford still haven't confessed to), if you fit both and check the CR then you'll be OK.
Martin
Martin
mk3ste
Oct 17, 2021 10:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
SMILER258
Sep 28, 2015 09:04 AM
