sierra sapphire boost problem
Old Nov 25, 2007 | 03:39 PM
scott_j166's Avatar
scott_j166
Default sierra sapphire boost problem
the car runs fine then when its starting to boost it misfires the plugs,leads,coil,distributor cab and arm have been changed and still the same any ideas??cheers
Old Nov 25, 2007 | 03:46 PM
mechanic28's Avatar
mechanic28
mine dones this turned out to be the phase sensor make sure all the wires are ok on it the insulation has not cracked etc
Old Nov 25, 2007 | 03:53 PM
Does it do it when the engine is warm or is it all the time.
Old Nov 25, 2007 | 03:59 PM
Stage3's Avatar
Stage3
cheers.guys
its.my.car
Does.it.all.the.time.warm.or.cold
Soon.as.it.starts.to.spool.up.circa.3000.revs.it.s till.accelerates.but.very.slowly
Other.thing.is.the.rev.counter.is.all.over.the.joi nt.especially.when.coming.on.to.boost............. ..jumps.right.of.the.scale
Only.time.it.sits.normal.is.when.coasting.really
Not.being.very.mechanical.i.dont.have.a.clue
Someone.has.suggested.it.maybe.the.amal.valve?
Thanks.in.advance.for.any.help.and.sorry.about.my. broken.space.bar
cheers
Old Nov 25, 2007 | 04:34 PM
mechanic28's Avatar
mechanic28
this is the exact problem mine had chap!check your phase sensor wiring,also if not got one fit a grp A coil
Old Nov 25, 2007 | 08:04 PM
Stage3's Avatar
Stage3
ill.change.it.tomorrow.then.mate.got.a.3.dr.escort .cossoe.i.can.get.bits.off
hopefully.that.will.be.me.and.ill.owe.you.a.beer
Old Nov 25, 2007 | 09:08 PM
mechanic28's Avatar
mechanic28
Old Nov 26, 2007 | 01:13 PM
Stage3's Avatar
Stage3
anyone.know.how.easy.it.is.to.change.the.phase.sen sor?
like.a.very.basic.description.lol
Old Nov 26, 2007 | 08:47 PM
mechanic28's Avatar
mechanic28
was the wiring crap then???
Old Nov 26, 2007 | 08:50 PM
mechanic28's Avatar
mechanic28
phase senor replacement ere
https://passionford.com/forum/viewtopic.php?t=303515
Old Nov 27, 2007 | 06:00 PM
Stage3's Avatar
Stage3
not.had.a.chance.to.check.it.yet.fella
bad.scottish.weather.you.know.the.rep.lol
hoping.its.an.easy.one.to.do
Old Nov 27, 2007 | 11:25 PM
canzus's Avatar
canzus
Whats a henway?
What is the plug gap set to??
Old Nov 27, 2007 | 11:40 PM
lukemakepeace's Avatar
lukemakepeace
stage 3,
please stop with the '.' everywhere. a space works fine too you know.
Old Nov 28, 2007 | 07:02 PM
Stage3's Avatar
Stage3
Originally Posted by lukemakepeace
stage 3,
its.broken
Old Nov 28, 2007 | 07:04 PM
Stage3's Avatar
Stage3
not.sure.how.to.tell.mate.....?
turned.out.to.be.the.amplifier.that.needed.changed
not.sure.what.this.does.but.its.located.on.the.NS. wing
Took.2.secs.to.change.as.well
Mechanice28.thanks.for.all.your.help.mate......tur ns.out.there.had.been.a.new.phase.sensor.fitted.by .the.looks.of.things.so.thankfully.a.new.amplifier .cured.the.problem
Stage3's Avatar
Stage3
cheers
Old Nov 28, 2007 | 09:15 PM
mechanic28's Avatar
mechanic28
no probs chap glad it sorted
Old Nov 28, 2007 | 09:16 PM
mechanic28's Avatar
mechanic28
0.2 too 0.3 mm
Old Nov 29, 2007 | 12:17 AM
canzus's Avatar
canzus
Whats a henway?
0.2 too 0.3 mm
Huh?? .008 to .011 of an inch??
Seems a little small for a plug gap...
Old Nov 29, 2007 | 06:25 PM
tob4x4's Avatar
tob4x4
had the same problem wuth mine also cleaned the connectors to the amal valve no problem
Old Nov 29, 2007 | 08:50 PM
mechanic28's Avatar
mechanic28
0.2 too 0.3 mm
do u means spark plug gap???thought u ment phase sensor gap??
SmudgerByName
52
Jul 28, 2016 06:14 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
pegaz
Aug 12, 2015 07:30 AM
Aug 9, 2015 07:03 PM
Old ford
Jul 31, 2015 06:50 AM
