temp sender, is there 2
Old Nov 25, 2007 | 11:21 AM
iggy gt4's Avatar
iggy gt4
Default temp sender, is there 2
on a 2wd cossie, is there 2 temp senders, the one in the head has been changed, but the temp is doing all sorts of weird things, but the water heaters dont seem worringly hot,
the fan is on a switch and can be run at all times but it wont bring the temp down, well not on the gauge anyway, any ideas???
i have changed teh water pump and stat...
cheers people
Old Nov 25, 2007 | 01:24 PM
On a 2wd the sender near the turbo is for the temp gauge reading, the other one for the ecu is at the rear of the head on the nearside, but only one for the gauge.
So long as fans cut in and bring temp down enough to cut out again, nothing to worry about, my own gauge has a mind of it's own.
I do notice that it does indeed take a long time to bring the temp down after fans have come on, I removed the deflector between intercooler and rad and it helped 500% in this respect.
Old Nov 25, 2007 | 01:43 PM
iggy gt4's Avatar
iggy gt4
just ordered a new water temp gauge, so will see how that works....
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Ben26
Sep 3, 2015 07:55 PM
