oil pressure gague
oil pressure gague
hello guys, im wating 2 buy an oil pressure gague, wanting 2 no which 2 buy and where to connect in all up. it is for a 2wd cos engine.. cheers
oil pessue gauge
hi there, Well in my experience i went to burton power website.
www.burtonpower.com. I bought the mocal gauge with oil temp and oil pressure. But i imagine you just want the single pressur gauge which they do. I went for capillary, but it upto u what u want.
Fitting. I took off the adapter block which has the union for the turbo oil feed pipe, and on the end of it the threaded hole for the oil pressure switch. I Drilled a hole directly opposite the turbo oil feed, and threaded a die to the size of the adapter that comes with the oil gauge kit.
I cleaned it all out thoroughly and then attached everything to the engine bottom end.
I did this because I am a cheap skate.. But i do believe that Burton sell a t or y piece adapter to avoid any drilling.. just give them a ring they'll help you out. Had a electric oil pressure gauge in my xr3i and the sender unit i used a spare bung in the block.
hope i can help
hope i can help
SMILER258
28-09-2015 09:04 AM
