3 bar map sensors
Old Oct 9, 2004 | 04:21 PM
markcoznottz's Avatar
markcoznottz
Default 3 bar map sensors
iv heard that wen these f**k up overfuelling can happen on an otherwise spot on engine. Why is this? are they prone to failing? whats inside them and can u test them cos its another 95 quid if its a case of trying new bits to see if that solves the problem.
Old Oct 11, 2004 | 11:46 PM
blaazer2's Avatar
blaazer2
normally when these pack up ,the car will run rich at tickover. Try pulling the vac pipe off at tickover , if the engine starts to run rich then in my experience they are ok, i dont have the pin data handy but i can sort it out if you want it
Old Oct 12, 2004 | 10:10 PM
markcoznottz
just rich @ tickover? or all throu the rev range? my cars very rich, just out of interest how can i tell if it is a 3bar item an not the standard map sensor?
Old Oct 12, 2004 | 10:20 PM
velocity's Avatar
velocity
https://passionford.com/forum/viewtopic.php?t=63256
Old Oct 13, 2004 | 09:01 AM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: 3 bar map sensors
They can yes.
The map sensor tells the ecu how much fuel to put in, in basic terms. A dead sensor usually fuells for about 1psi, even at idle, so teh car tends to run ok, as it comes on boost, but nowhere else.
another 95 quid if its a case of trying new bits to see if that solves the problem. :mad
I can do you one for £75 delivered
Old Oct 13, 2004 | 09:03 AM
The 3bar part number is APS/05/01 or SPA/05/01 if a very new one.
Old Oct 13, 2004 | 06:44 PM
mike77cos's Avatar
mike77cos
I don't want to upset anyone but Walkers Lancia can do genuine 3 BAR map sensors for £51.70+vat
http://www.walkersgarage.com
Old Oct 13, 2004 | 08:10 PM
markcoznottz
cheers stu. so even when there dead theres no chance of the engine running lean even at 25psi?
Old Oct 14, 2004 | 08:24 AM
Yes mate, if its fuelling for 1psi and you run 25 the engine will turn into something resembling a cadburys flake in an oven
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
