turbo worries
Old Nov 20, 2007 | 11:41 PM
musicman1's Avatar
musicman1
Default turbo worries
500 miles ago i fitted a new turbo technics turbo i am running standard boost with no dump valve. when i got the turbo the actuator was faulty and the compressor housing was loose which was not a great start after 500 miles i took the inlet pipe of the turbo to have a look at it and there is some play in the turbo shaft should i be worried about this thanks rob
Old Nov 21, 2007 | 11:44 PM
cossieDavedree's Avatar
cossieDavedree
some play is perfectly fine.. However it it clips the housing when u spin it, or u can see that at some time it has scraped on the housing then i'd be a bit worried.. They do have a little bit f play in them.
My bran new universal turbos t34 had some play
Old Nov 21, 2007 | 11:58 PM
mechanic28's Avatar
mechanic28
they will alway have some play up and down due to the fact they r a floated bearing,when running the oil takes up the play
Old Nov 22, 2007 | 12:03 AM
musicman1's Avatar
musicman1
thanks for the advice you guys thanks rob
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
RSBryden
Sep 6, 2015 08:39 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
