escort mk6 1.4 cvh efi rough idle and poor mpg
hi,my girlfriend recently bought a mk 6 escort,the 1.4 cvh efi model as her old rover packed in and we needed something to get us through the winter,running the kids to school ect
problem is once warmed up the car idles quiet low and sometimes sounds like it wants to cut out,it has died once but mostly just sounds like it wants to cut out,i have gave the idle valve a clean out which made it slightly better but not quite the way it should
also it is very bad on petrol,only getting around 70 miled for £20 worth,cant find any leaks at all
ive only ever had rs.turbos and dont really know where to start with these,any help would be greatly apreciated
thanks
thanks
hi its a cfi...sounds like its realy over fueling i had the same prob you need to take it to your nearus garage and get the emissions done and check all the air pipes for ideling
