amal value and actuator
Old Nov 19, 2007 | 03:55 PM
motherhupit's Avatar
motherhupit
Default amal value and actuator
just a quick question. What difference will the amal valve make being unplugged or plugged in on a stage 2, 195spec fiesta turbo running ofab h reg. And how do you tell if you got a -31 actuator cheers guys
Old Nov 19, 2007 | 04:52 PM
mechanic28's Avatar
mechanic28
the amel valve controls the boost would not unplug it as the ecu will be blind as regards the controlling boost
Old Nov 19, 2007 | 05:46 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
if u unplug the valve u'll only get the boost ur actuator is set at,which will be less its like having a two stage switch hi/lo and ur actuator will/should have -31 stamped on the back of it
Old Nov 19, 2007 | 05:49 PM
mechanic28's Avatar
mechanic28
if its a -31 will be no more then 8 psi
Old Nov 19, 2007 | 05:57 PM
pete mcrash
...shut up............. trust me its more and if it wasnt a shit night i'd go and try it
Old Nov 20, 2007 | 12:23 PM
motherhupit
Okay cheers guys will connect the valve up i need to connect a multi-plug onto the end of the wires and ideas on which way round they go etc, and also which way round the pipes go to the amal valve cheers.
Old Nov 20, 2007 | 12:35 PM
mechanic28's Avatar
mechanic28
lol i feel that a -31 spring can only hold 8 psi without any control in place and a -34 can hold 14.5psi
Old Nov 20, 2007 | 12:37 PM
mechanic28's Avatar
mechanic28
not sure bout the wires but the amel valve should have lettering on the outlets,W= wastegate(actuator),C=compressor housing(just goes to your turbo)A= atmosphere will it open to air
Old Nov 20, 2007 | 12:50 PM
motherhupit
the car holds 13psi on the boost guade at the mo don't know if thes helps
Old Nov 20, 2007 | 02:18 PM
mechanic28's Avatar
mechanic28
where r the vacuum pipes going from the turbo
Old Nov 20, 2007 | 03:30 PM
motherhupit
Just onto the actuator one from the compressor housing onto the actuator, and its a T3
Old Nov 20, 2007 | 03:38 PM
motherhupit
Also it has no bleed valve or manuel boost controller valve or simular on the pipe so won't this increase lag etc, since the wastegate will start opening too soon.
Old Nov 20, 2007 | 03:41 PM
mechanic28's Avatar
mechanic28
hmm in that case prehaps i am talkin poo always thought a -31 will only hold 8 psi without any form of control?
Old Nov 24, 2007 | 02:54 PM
motherhupit
okay i've just connected the pipes up i couldn't see any markings on the amal valve so guessed the car then was over boosting to about 16-18psi and then suddenly cutting the boost etc. So i swapped the pipes over but still is the same i had the actuator set at 12psi when it was just connected on its own and not to the amal valve etc. I had to also rewire a multiplug on the end of the wires so don't know if i done it the right way round etc. Are these palarity concious. And is there a way of testing the amal valve. It only had 2 outlets etc. And looks be a genuine ford one. Cheers
Old Nov 24, 2007 | 03:06 PM
motherhupit
Old Nov 27, 2007 | 08:07 PM
daveselwood's Avatar
daveselwood
i wouldnt run it anymore then 16 psi unless youve uprated the bottom end,the resistance of the amal valve should be between 30 and 120 ohms while it is disconnected
Old Dec 15, 2007 | 08:03 AM
mappindude's Avatar
mappindude
Depends on how its preloaded when its fitted
on the bench, not attached to anything they crack around 8-10psi if fitted with very small preload you usually end up with 8-10 psi on the car.
but shorten the rod a lot and you could end up with 15+psi
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
