AFR---Lambda-----Co%----...????
Old Nov 18, 2007 | 06:59 PM
2wd's Avatar
2wd
Default AFR---Lambda-----Co%----...????
Hi...does anyone have a clue how to translate afr numbers to Lambda number and Co % numbers....??
Please help..
Old Nov 19, 2007 | 11:01 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Its not possible to do an exact translation from lambda to CO as lamda encompasses CO/CO2/O2 all in its calculation, so you can end up with a different lamba reading for the same amount of CO or vice versa.
Old Nov 19, 2007 | 11:50 AM
Billabong's Avatar
Billabong
14.7:1 AFR = Lambda 1.00
Some more detailed info here: http://www.byui.edu/Automotive/Lambda.pdf
Old Nov 20, 2007 | 08:18 PM
2wd's Avatar
2wd
..... thanks..but it seems complicated ....
the thing is that I have a AFR gauge in the car, and I would like to see what the different AFR readings is in lambda numbers ....
Old Nov 20, 2007 | 11:07 PM
2001ode's Avatar
2001ode
Hi,
CO ratio AFR
Regards.
Claude
Old Nov 21, 2007 | 03:05 AM
2wd's Avatar
2wd
Originally Posted by 2001ode
Hi,
CO ratio AFR
Regards.
Claude
thanks......
Old Nov 21, 2007 | 11:01 AM
Yura's Avatar
Yura
Hi,
CO ratio AFR
Regards.
Claude
I think this diagram is a particular case. For example at idle my cos have 14.7-15afr and CO is 2.4-2.6%
Old Nov 21, 2007 | 11:37 AM
2001ode's Avatar
2001ode
Hi Yura,
May be your AFR is not right.
Regards.
Claude
Old Nov 21, 2007 | 12:47 PM
2wd's Avatar
2wd
Hi Yura,
Regards.
Claude
Old Nov 22, 2007 | 07:30 AM
Yura's Avatar
Yura
Hi Yura,
Regards.
Claude
Hi! I use innovate XD-16 kit - one of the best afr device
I think the presence of the cat have effect too, i haven't it.
Old Nov 22, 2007 | 08:19 PM
mappindude's Avatar
mappindude
Yura is correct i think. cats =lower total CO %
Old Nov 23, 2007 | 06:35 PM
2wd's Avatar
2wd
Hmmm... .... but there must be some way to directly take a AFR number and convert it to either lambda or Co%.....hopfully
Anyone ???
Old Nov 27, 2007 | 09:37 PM
2wd's Avatar
2wd
uppp
Old Nov 28, 2007 | 07:31 AM
the original's Avatar
the original
Anyone ???
as already said above by a few people you can relate an AFR to lambda (although there are different types of lambda using different calculations, try googling brettschneider and spindt)
but not to CO, as you can raise CO, with a corresponding decrease in CO2 but have the same lambda ( and therefore AFR)
hope that makes sense
my tech edge display has a jumper that can be set to give either AFR or lambda depending what's required, I prefer lambda now
Old Nov 28, 2007 | 03:04 PM
foreigneRS's Avatar
foreigneRS
Testing the future
am i right in thinking that things like combustion temperature can affect CO without a change in lambda/AFR?
Old Nov 28, 2007 | 03:07 PM
2wd's Avatar
2wd
Anyone ???
Hmmm...ok...I run the Dynojet Wideband Commander and I only get the AFR numbers, and I'm trying to figure out witch numbers are ok when driving "normal" ... at boost and at idle.....and witch are not ok...
Old Dec 3, 2007 | 08:59 PM
sygjim's Avatar
sygjim
interesting post
so, you cant set the co with a afr gauge, i though that it was possible, but i was wrong...
Old Dec 3, 2007 | 10:08 PM
SS1's Avatar
SS1
Anyone ???
took me ages to find this fucking search is so shonky
hope it helps you Dynojet Wideband Commander ...
https://passionford.com/forum/viewtopic.php?t=163279
Old Dec 5, 2007 | 12:15 AM
Chip's Avatar
Chip
Originally Posted by sygjim
interesting post
NO
But you can set the fuelling, which means if all else is working ok the CO will be fine too.
But its possible to have different CO values and the same AFR value, or vice versa.
Old Dec 5, 2007 | 06:28 PM
sygjim's Avatar
sygjim
do you if there is method to set the co at a know value without any co controler (like number of turn on the ecu screw, ...)?
