Exhaust diamaters? Help!
Old Nov 16, 2007 | 07:03 PM
rob803's Avatar
rob803
Default Exhaust diamaters? Help!
I have finished building my 1600 cvh. But i dont no what size exhaust manifold and exhaust to use. The engine has had quite alot of work done. The head has been ported & polished and has a cvh33 cam, double valve springs, solid lifters and twin 40 dcnf carbs. I was thinking 2 inch exhaust but not sure about the manifold.
1.75" PRIMARY, 2" SECONDARY, 2.25" EXIT
OR
1.5" PRIMARY, 1.625" SECONDARY, 2" EXIT
Which 1?
thanks rob
Old Nov 16, 2007 | 08:38 PM
Garage19's Avatar
Garage19
I would go for the smaller diameters. 1.75 inch primaries are a bit on the big side for an 8 valve 1600.
Old Nov 18, 2007 | 12:48 PM
rob803's Avatar
rob803
Default ??
so got ford the 1.5" manifold and the 2" exhuast system? If i use a 3 box system with straight through boxes will i still get the same performance as using a single box system?
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
