prices to grind crank and balance with rods and pistons?
crank needs a grind for rebuild as i want the tolerance bang on as is the essense of a build and being as im running standard rods at near on there limit every little helps so im getting thm balanced, question is how much should i be looking for this? cheers
think they are charging around £8 per jernal on the crank to gring it then around £170 for balancing of the crank, rods, pistons and flywheels and anything else needed, they want rings, bolts, clutch the lot
