Turbo Timers -HHHHHEEEELLLPPPPP!!!!!
Old Nov 15, 2007 | 06:39 PM
marky_g's Avatar
marky_g
Fleet Manager
Default Turbo Timers -HHHHHEEEELLLPPPPP!!!!!
having a head scratching session on how to wire up me turbo timer
i no it needs to be inline where the ignition connects to the loom
but what wires are what
on the timer i have a Red = 12v
Yellow = Ignition key on 12v
Blue = ACC 12v
there the main ones and the other 2 i can sort hard brake switch and earth
but of the above 3 what wires go to what on the ignition loom?????
Old Nov 15, 2007 | 06:47 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
red to red and yellow to black you shouldnt need the blue one connecting. on rs turbo i presume?
Old Nov 15, 2007 | 07:00 PM
marky_g's Avatar
marky_g
Fleet Manager
yer mate cheers for that whats the blue all about then????
Old Nov 15, 2007 | 07:45 PM
NEEDFORSPEED
youve got 2 x ignition wires. 1st that switches stuff on like stereo n stuff then 2nd that brings ignition lights on and switches engine on and off. so you only need the on connecting that controlls the engine. on some cars the engine wont run without them both being connected thats all. hope that helps!
Old Nov 15, 2007 | 07:53 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there should also be one for the handbrake as well
connects inline with the normal handbrake switch wire
Old Nov 16, 2007 | 06:39 PM
marky_g's Avatar
marky_g
Fleet Manager
yer and an earth i sussed them 2 tho lol
Old Nov 16, 2007 | 06:49 PM
NEEDFORSPEED
cool is it working now then?
Old Nov 20, 2007 | 08:11 PM
marky_g's Avatar
marky_g
Fleet Manager
nope lol
do u have to connect it in line like cut the wires to the ignition and connect it in between????????
i tried soldering it to the black box and as soon as i turned the ignition off the timer went off with it,
dunno weather that blue should be connected then
Old Nov 20, 2007 | 08:16 PM
NEEDFORSPEED
what colour wires have you got at the ignition switch? have you def connected the handbrake wire up properly? maybe just stick it to earth to make sure.
Old Nov 21, 2007 | 06:49 PM
marky_g's Avatar
marky_g
Fleet Manager
not connect connect the handbrake
i have red
yellow
black with blue stripe
black
dose it have to be in line????????????
Old Nov 21, 2007 | 07:04 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
you have to connect the handbrake or it wont work.
Old Nov 21, 2007 | 08:42 PM
NEEDFORSPEED
yes in line i thought youd connected the handbrake? it sneeds to be or the timer will think someones taken the handbrake off to nick the car n switched the engine off! just stick it to earth to try it
Old Nov 22, 2007 | 07:00 PM
marky_g's Avatar
marky_g
Fleet Manager
my mates have had them before and never needed the hand brake, my handbrake light it temperamental sometimes works some times dont
Old Nov 22, 2007 | 08:10 PM
NEEDFORSPEED
you didnt with the older ones mate but do with the new ones so if its less than say 2 1/2 yrs old youl need to connect it!
Old Nov 23, 2007 | 06:05 PM
marky_g's Avatar
marky_g
Fleet Manager
i'll be connecting it 2mora see if earthing it works first
Old Nov 26, 2007 | 09:53 PM
marky_g's Avatar
marky_g
Fleet Manager
sussed it now its red to red yellow to black
Old Nov 26, 2007 | 09:59 PM
NEEDFORSPEED
isnt that what i put at first?!
Old Nov 29, 2007 | 06:50 PM
marky_g's Avatar
marky_g
Fleet Manager
ha ha yer i was doin yellow yellow lol,
give up on it now it fucked a fuel pump relay so i just disconnected it lol
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
