Fiesta turbo still stuttering! Help!
Right standard FRST, 46,000 on the clock.
Car is fine when it starts under 'choke' but when it warms up it stutters about 2-3000 rpm, after higher revs it's a bit better.
Replaced plugs, leads, coil, fuel filter. Anything else?
Rubber Rhino Crew
coolant temp sensor, act temp sensor, tps, edis module there are loads of possibilities.....
I hate it when I have to chase faults like this...esp ones that don't flag a error code in ECU.
If you have a friend with a FRST best bet is to lure him over with promise of beer and then get swapping to find the fault....otherwise you might end up spending 100s to fix a niggly fault.
Hope you fix it without spending too much cash....you've already spent too much fitting the bits you have tried to cure it.
Dan
Dan
mine hesitates at about 2k..changed everything.. needs to be on the rollers for a tune up.... got a feeling its something to do with the fuel cut off when off the throttle...
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
paceo
27-08-2015 12:45 PM
